CDMA version of the fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. 16 or 32 GB / Model A1349 / CDMA compatibility.
419 Questions View all
Volume buttons stopped working after battery replacement.
So I thought I had done a successful battery replacement on GF's iPhone 4. It seemed to go fine and phone worked afterwards. She is getting long life from battery and she needed this as her phone wasn't making it through even half a day. However, the volume buttons on the side no longer respond.
I must have hit something inside when doing the replacement. Any idea what I did? And how to fix it?
Lack of buttons isn't end of the world as software volume control still works fine. But I'd like to fix this if I can. I wonder if I pulled off a ribbon accidentally.
Add a comment
Chosen Solution
When you open the phone you may hit the cable that goes to the voume contol. If you open again the phone there are 3 screws for the volume buttons, try to press the cable but dont push it very hard and check that the 3 screws are ok.
Add a comment
Try a hard reset or restore the phone you probably unplugged the battery while is was powered on.
Add a comment
Add your answer
Jon Cole will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 1,005
