Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
Question Closed
Plug works, battery won't charge
Old battery was shutting off randomly, so I replaced it. Things were fine for a week, then when I plugged in to charge I would get a picture of a plug in the battery icon, and it would intermittently show the lightning bolt and eventually charge the battery. Now it will just not charge. The phone works plugged in. My wife's 3gs works with the same cord/charger combos.
Bad replacement battery, or a phone issue?
Add a comment
1 Answer
Chosen Solution
footstepfollower, make sure that you dock connector is nice and clean and that you do not have any bend, broken or corroded pins. You can clean it with some high grade isopropyl alcohol on a cotton swab and/ or a few puffs of compressed air. If that should check out okay, I would suggest to take a look at the battery. Make sure it is still connected right and if it is, replace it once more. Hope this helps, good luck.
Score 2
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 327
