Before merging with HP, Compaq manufactured a full range of laptop computers. Now they are manufactured by HP mostly with basic features.
296 Questions View all
My compaq presario f700 has a blank screen, power working
I have tried hard reset, my ram is sufficient and i think there is some problem with the graphic card nvidia chip.
i have read many forums and found out it has to be reflowed or solder needs to be fixed.
any details of its repair?
Score -1
Add a comment
muzammil , the first thing I suggest you try is to attach an external monitor to it. If that works, you will at least know that it is not a reflow situation. Then the problem is with either your inverter, your LCD or your cables. If it does not work, you could consider a reflow. Problem with that, it is not as easy as it might sound. If you never have done one before, I would definitely take the time and work on some old boards first. Make sure that you have the right tools (sorry, hair dryer's are not the right tool) You need to be able to control temperature for a set amount of time etc. Take a look at this this video for the professional approach and this one for a more home made approach. I recommend you look through this note. It does explain it pretty good. This is not to say that an oven or a hot air gun will not work, but it will not be as accurate and thus has a higher degree of failure. Hope this helps, good luck.
Add a comment
thanks for the advise... i got it repaired from professional and planning to change my laptop soon.. :)
Add a comment
it is working ok but when i stop and tray again to start it is not starting
Add a comment
Add your answer
muzammil will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 7
All Time: 3,052
