Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
I dropped my iPhone. Why won't it work?
I bumpped into someone and dropped my iPhone on a hard surface. There are no visible cracks but the phone no longer responds to anything now. The screen turns white at times but nothing else happens.
Score -1
Add a comment
If you are confident enough, open up your phone and make sure all ribbon cables are seated properly and not knocked off after the drop. Come back if you are still stuck.
Add a comment
I had the same problem but I did what you said to do and one ribbon cable was disconnected, then I connected it but it still doesn't want to do anything.
1 Comment:
xdamonster, this question is is pretty old and was never revisited. If you need help with you phone, I suggest you ask your own question. Give as much detail as possible. Use this link http://www.ifixit.com/Answers/Ask/iPhone... to ask ....good luck.
by
Add a comment
Add your answer
Jjamied56 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 9
All Time: 1,888
