Model A1288 / 8, 16, or 32 GB capacity
451 Questions View all
My right iPod touch earphone is doesn't work!
Recently I used my iPod Touch with my friends speaker.
Not as usual, my iPod Touch little experienced some disruption in producing his voice, a voice screeched, and my iPod Touch suddenly hangs.
After I got home, I try to listen to music using my earphones. and I was shocked because the right earphone made no sound at all, I was wondering could this problem from my earphones that have been long time since I used, I ended up using my stereo speakers I used to wear.
I try to play a stereo knob settings, to the sound of the speakers from the left was normal with no problems, and when I set it to listen to voices from the right speaker, did not hear a sound there.
it was clear that the problem comes from my iPod Touch
So..Is there someone here who can help solve my problem?
Best Regard
Jagger
Score 1
Add a comment
Chosen Solution
Have you tried different headphones with the unit?
There might be dirt in the headphone jack causing a weak connection. You might try a tightly twisted Q-tip to twist in the jack holding it upside down for any dirt to come out. You can also apply a little tiny bit of high grade isotropic alcohol (70%+) to the Q-tip and rub it in the port a little bit to loosen up stubborn dirt, but let it dry for 30 mins before trying it out again to be safe.
Score 2
1 Comment:
Finally..I've been waiting for long time for the answer. You saved me Man!! I try to clean the Jack just like you said, but it don't change anything. The sound's still have the same problem.
I thinking about maybe my iPod touch should go to the "hospital" lol. But it's really hard in here to find apple expert who can solve problem like this.
I really appriciate your answer Man!
Big thanks!
Jagger
by
Add a comment
I Got the same problem. but what its with me left headphone *sigh*
what i do (and yes i know this sounds crazy) is that i plug in my headphones, put on a song. only the right one works so i Knock the screen. Yes ROFL you heard me :L
i`ve deducted that my iPod touch has some problem internally, but when i knock it with my finger (not tap, knock) not with my knuckles, but that Joint on your finger above your knuckles :L
it sounds crazy, but it works for me :L it stopps working. so i knock the screen with one finger and if it dosent come back on. i knock it again at a diffrent spot, and again at a diffrent spot harder and harder till the left one works again it stays good like both headphones work untill i put it down. or untill somthing else slightly tapps it, quiet annoying. i just gennttllyyy put it down. and yeah its all good
dw, the screen wont crack or break becouse it is made of a special tamperd glass, thats why it dosent scratch as easy as a phone or somthing :)
stab it with a knife and i bet the knife will break :L
ok ok ok im going of topic (:
but yeah. its crazy, but hey, its worth a shot :)
and it works for me :L
i need to go and take it to a repair shop soon but i dont know anyone who fix`s iPod Touches and my warrenty is over :(
Fml
Score 1
1 Comment:
Knock the screen?? You're not kidding?
by
Add a comment
This has happened to me too with the left earphone. I have found out that the main reason why it doesnt work for me is that i have wrapped my headphones around my ipod too many times and now for the jack to work i either need to push the earphone jack straight in or push the earphone jack down.
Add a comment
My IPod is not using the front speaker and only uses a ear phone of Bluetooth for a dock! what should I do?
Add a comment
why don't you try adding a piece of aluminum foil to the end of the headphone jack, since maybe the headphone jack has bad contact with one of the headphones aluminum can help that problem.
Add a comment
I did what you sayed panchita but is this normal..
Add a comment
Holy $@$*, Rajeev, You Saved My Earphones xD. I knocked my phone a little and the left earbud suddenly started working. I bought it 10 mins ago and went crazy that I broke it. Thx xD
Add a comment
Add your answer
jagger mail will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 10
All Time: 33,690
