The Samsung S860 is a high resolution digital camera with 8.1 megapixels, 3x optical zoom, Samsung SHD Lens, 2.4-inch LCD screen, and Digital Image Stabilization (DIS).
12 Questions View all
Why won't my camara turn on?
I have put new batteries in and checked they are the right way round. When I press the power switch the camera status lamp on the back flashes green but nothing else hapens. As soon as I take my finger of the power button the flashing stops even if I hold the power button down for several seconds (approx 20).
2 Comments:
does the screen receive power?
does the lens extend?
did you buy it new or used and where?
by
This Camera Won't Turn On
by
Add a comment
1 Answer
Helen Smith, check your lens. Make sure it is properly retracted. Check the clearance of the lens against the housing. It should be equal all the way around. The camera will shut off if the lens does not extend or retract. If that looks okay, make sure that you battery connectors are not corroded and the the door contact touches both batteries. If that is okay, you may have to take it apart and take a look at the individual components. It is possible that your DC-DC IC has issues
2 Comments:
Thanks. The lens doesn't extend, and the screen doesn't recieve power. I bought it new approx 4 years ago, and it worked fine last time I used it. The camera has been untouched, but safely stored in a protective case for about 2 years. I don't take many pics!! The clearance of the lens look ok The battery connectors look ok and the door contact appears to touch both batteries, so it looks like a repair job is needed. Thanks for the advice.
by
Old turkey 03, or Helen Smith, I have the same problem. I have recharged the batteries and connections look good. Stored it good place for I don’t use it that much.worked good 4 months ago. But lens won’t extend.so do I go to repair shop or what? THY.
by
Add a comment
Add your answer
Helen Smith will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 63
All Time: 3,440
