Intel Core 2 Duo T5500 1.66GHz, 512MB RAM, 80GB HDD
11 Questions View all
PCMCIA has come out, can't get it back in
While browsing, my left hand accidentally pushed in the black button next to the PCMCIA card, and the button popped out. When I pushed it back in the black card slid out. Now I can't get them both in at the same time. Every time I push the card, the button pops out, and vice versa.
Score 1
2 Comments
Screw it. I just broke off the tab. Now the PCMCIA card template slides into the slot and stays there. Much easier now. Now I can relax. :-)
by
No offense but that is the wrong answer. Assuming there is nothing already broken, to properly reinsert the card holder do the following: 1) remove the card holder completely. 2) with the holder out, push the eject button all the way in and it will lock in place. 3) reinsert the card holder and it will gently lock in place. Note that the card holder requires proper orientation.
by
Add a comment
Chosen Solution
The PCMCIA card release button will not remain inside of the laptop unless there is no card currently situated in the laptop. To get the button back in with the card in place:
1. Remove the card from the port.
2. Push the button back in to make it stay flush with the case.
3. Put the card back in the laptop.
If the button will not remain in the recess after the card has been removed, either the port release mechanism is broken, or there is something still in there. If it is broken, the PCMCIA port is very simple to replace as there are 4 screws holding it in place and then pull it from the plug connected to the motherboard to install a new one, but you will have to disassemble the laptop to get to it, and will take some time to do.
Score 1
Add a comment
It happens sometimes. Don't worry there is a spring inside the slot which let it come out. YOu need to press hardly inside it then automatic it will stuck at there.Thanks.
Add a comment
Add your answer
Rick Maskell will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 1,216
