Model No. A1367 / 8, 16, 32, or 64 GB capacity
White screen/Charging won't work..
So I'm really new to all this screen fixing stuff. I want to learn how and such. So I am trying to fix a iPpod 4 Generation screen which was cracked.. I got to the point where I connected the LCD and all that but when I turned it on the first time it was always white.. So I just gave up on that for the day. The next day I tried it again and that and all of a sudden the screen turned on properly.. but the screen wasn't working when I touched it.. I was about to glue it on permanently because when I pressed the screen down against the back it seemed to work, the touch and everything.. It was late so I was going to do it tomorrow.. Then today I tried putting the screen back on but when I turn it on its white again.. I try messing around putting the LCD around and nothing works.. Still white. I had it before but I don't know why its not working now. As well sometimes its not charging.. It will just stay dead and won't charge.. I finally got it to charge a bit but I can't figure out this white screen! HELP?!?!
Score -1
Add a comment
1 Answer
Chosen Solution
Don't worry, when you install a brand new piece of hardware in an iPod touch, you'll get a white screen. First, press and hold the home and power buttons for a couple seconds to give it a hard reboot. If that doesn't work, make sue that all the connectors are properly fastened and the ZIF connectors are clipped down with the bar down. And worse case scenario, you may of severed the cable to the display, and if it is, you'll have to order a new one. Hope I helped, and happy repairing.
Add a comment
Add your answer
Devon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 656
