iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
904 Questions View all
Something's wrong with the hard drive or the system?
I bought a 160gb iPod classic and every time I try to put music on my external hard drive only copy up to 1500 songs and then freezes Itune me and I can not close the program asks me to restore the ipod as manufacturing, and do nothing. I try to close the program and itune will not let me, I try to turn off the computer and I can not shut, I looked to see if the iPod disk errors and says it's okay. I restored it about 8 times and I've put music and videos but I always delete everything. I crushed and Selection Menu to enter the diagnostic system ipod and I put the manual test where I enter the IO and tells me everything is fine. I have already given several Format directly from the Windows 7 and anything either, I always delete everything from passing over 1300 songs and freezes my entire computer. No longer have to think of this company because Apple gives no solution has this issue.
I have read everything I have in other Web pages and believe me now if I have the idea of ​​what happens q as my test result is that my hard disk has many bad sectors and that tells me the hard drive of 160gb Ipod this broke .... Now if someone gives me another solution they are grateful but a million or indicate to someone as I buy the hard drive on the Internet, I mean that it looks and name one that is better than the trash that brings the Ipod.
Retracts: 131
Reallocs: 16368
Pending Sectors: 8
PowerOn Hours: 1004
Start / Stops: 12993
Temp: Current 31c
Temp: 12c Min
Temp: 54c Max
If anyone can help me a lot ... they are grateful I know I can do?
Apologize for my English because I am writing in the Google translator ..
Add a comment
1 Answer
Chosen Solution
It does sound like bad sectors. Try to run CHKDSK with your iPod in disk mode. See what it tells you.
Score 2
3 Comments:
And as you run CHKDSK with the iPod in disk mode?
thanks...
by
This may help you to run CHKDSK. When in Disk Mode the iPod is viewed as just another external hard drive. The iPod is formatted using FAT32, so it would appear under Windows, and should even show up during boot if it's plugged in.If Windows is claiming it cannot run CHKDSK on the drive, it may be because the drive is in use. Ensure that you have iTunes closed when you try to run it. All you will have to do is to turn iTunes off, place the iPod in Disk mode, run CHKDSK x: Where X is the letter for your hard drive.
by
Muchas Gracias, voy a tratar de hacerlo...
by
Add a comment
Add your answer
Modesto Vela will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 8
All Time: 2,316
