2.26 or 2.4 GHz / White plastic unibody enclosure
645 Questions View all
Logic Board won't power up; where to start?
I buy broken MacBooks and try to refurbish them. I don't do it to make money, really, but more of a hobby. If I can repair one to working condition and make a profit, great, but I certainly don't buy a machine with the assumption it will be an "easy fix".
That being said, I have a number of these 2009/2010 MacBook Unibody (model A1342) machines that have had various issues (liquid spills, no power, etc). I've gotten to a point with a few of them where I simply cannot find any problem with them. I've tested the top case/power buttons to ensure their functionality. I've checked over the logic board with a fine-tooth comb and have found no signs of liquid damage or burning. I cannot get the board(s) to power on even with a manual jump (using a known-good magsafe board and known-good charger). All boards receive power fine (and all will even charge batteries when attached). They simply won't power on.
My question (after all of that backstory) is: Where should I go from here? I could of course take a known-working logic board and compare/test each component with my volt meter, but with 10+ boards that would take a while. Is there a particular part of the circuitry I could start with--perhaps a "power on" circuit? Is there some main power fuse or gateway that I should check after confirming the top case and DC-in board are working fine? Is there anything obvious that I could be overlooking (something similar to not having the top case ribbon cable unplugged, etc)? I realize that sometimes the logic board can just be "dead", but certainly there's always some particular cause for failure (even if I can't identify is visually).
If I failed to provide any pertinent information, feel free to let me know! Also, if there's someone who specializes in troubleshooting this particular model, I'd love to pick your brain about a few things (in general) regarding the A1342 via email. Let me know! Thanks in advance for any replies.
Score 1
1 Comment
I’ve found this helpful. I was helping out my mother reorganize recently and stumbled appon her, as she said, “fried Mac”. 2010 MacBook A1342. We talked about it and we both recalled the day she dumped her water on the face of the keyboard... Memories flooded in as I remembered the time and hassle she went though with Apple as they targeted just about everything else without any luck. That was 2012. This thing is practically “new”. It wouldn’t start. So I tried out the “jump start” method. *angelical Mac sound*... 2secs later, crashed. So I went to the ram and pulled them out, flipped them around, jumped it. It was now booting up and never got to the login screen. Jumped again, now going to press shift+c... Right as I pressed shift, it crashed. After testing other keys it seems to be random ones that does it. I’m contomplating replacing the keyboard or full upper case.
My question is why? Why does the keyboard cause this common problem for people??
by
Add a comment
1 Answer
Chosen Solution
There are 4 pins at the flex cable connector of the keyboard case that goes to the slot at the Logic board. Problem might be that the flex cable of upper case with Keyboard became faulty. Now, to isolate it, short circuit between right 2 and left 2 pins of the keyboard connection slot residing on Logic-board with a pair of tweezers. Be careful not to short anything else that may fry the logic board. If this act starts up your unit, replace the upper case with keyboard. Otherwise, the problem resides somewhere else and we will be discussing on that later.
3 Comments:
Thanks for the reply, Puru. I will try that method of power-on this evening and let you know if that worked for any of them. As a pre-thought, before I try the pin-short method, what is the difference in that method of powering on and simply using the power pads (on board above the keyboard ribbon connector) to power the logic board up? Just curious.
by
I’ve found this helpful. I was helping out my mother reorganize recently and stumbled appon her, as she said, “fried Mac”. 2010 MacBook A1342. We talked about it and we both recalled the day she dumped her water on the face of the keyboard... Memories flooded in as I remembered the time and hassle she went though with Apple as they targeted just about everything else without any luck. That was 2012. This thing is practically “new”. It wouldn’t start. So I tried out the “jump start” method... *angelical Mac sound*... 2secs later, crashed. So I went to the ram and pulled them out, flipped them around, jumped it. It was now booting up and never got to the login screen. Jumped again, now going to press shift+c... Right as I pressed shift, it crashed. After testing other keys it seems to be random ones that does it. I’m contomplating replacing the keyboard or full upper case.
by
@scarlett_shea Keyboard is connected to the logic board by the ribbon cable. In order to push data to the logic board it uses power lines that end in the keyboard but start elsewhere, on the board where you have chips, mosfets, buck converters and so on. If power is drained endlessly by a keyboard shorted to ground, several parts that are one way or the other related to the keyboard stop working properly or completely.
If jump starting the Mac with keyboard disconnected doesn't allow the machine to boot, it means something else is damaged, logic board or attached parts, including battery and so on. Thus try disconnecting keyboard and battery and see if it boots. If not, you can repeat the test disconnecting all other cables from the board and see if it starts booting. In case nothing works after this basic testing, you're left with a damaged logic board.
by
Add a comment
Add your answer
Steven will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 11
All Time: 3,512
