DIY guides for many household repairs, ranging from furniture to plumbing solutions.
3885 Questions View all
Light works on Electric Fireplace, but heat will not go on. Why?
Electric fireplace insert has two sections that blow heat. I noticed that one did not work, and it became louder. I let it run for quite a while, but one day noticed that the plug was hot as blazes and the wall behind the plug was also hot. In fear of burning my house down, I unplugged it and am scared to use it. Can I fix it. They don't sell inserts for those things ANYWHERE.
1 Comment
Matt, what may help is to post lots of images. Model numbers and serial numbers are also a good help. the inserts usually consist of heating elements and fans, so that where I would start. have you disassembled any part of it yet? The plug and plate probably get hot because the insert is drawing a higher amperage. Keep it unplugged until it is fixed.
by
Add a comment
1 Answer
Chosen Solution
Matt, clean the filter and your blower (fan) make sure you remove all dust and debris. It sounds as if your blower is not working right.
Score 2
4 Comments:
I will try that. Thanks.
by
Only used a few times and blower quit working. It lights up but no heat. Is there something I can check
by
If you have your Manuel from when you purchased it see if after the description of your Manuel shoul give you your fireplace insert information, then call the number in your Manuel for the part.
by
Just broke one down for same reason and wires were burnt into. Am now looking for wiring diagram as wires were burnt too bad to tell where all of them went.
by
Add a comment
Add your answer
Matt will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 89
All Time: 23,503
