Using a Floor Jack
  1. Using a Floor Jack, Using a Floor Jack: step 1, image 1 of 2 Using a Floor Jack, Using a Floor Jack: step 1, image 2 of 2
    • Place the hydraulic floor jack under the vehicle until the saddle is directly under the crossmember.
    • The crossmember is the long metal support beam that runs underneath from the front fender to the rear fender on both sides of the car.
    • The saddle is the round metal part of the jack that moves upward as you pump the jack up.
  2. Using a Floor Jack, Using floor jack to lift car.: step 2, image 1 of 1
    • Push downward on the jack's lever to lift the saddle upward so that it contacts the crossmember. Continue pushing downward on the lever to lift the car upward.
  3. Using a Floor Jack: step 3, image 1 of 1
    • Place the jack stand under the jack mounting point.
    • The jack mounting point is a metallic protrusion beneath each of the car doors.
  4. Using a Floor Jack: step 4, image 1 of 1
    • Raise the jack stand until it contacts the jack mounting point.
    • In the event the floor jack fails, the jack stand is designed to prevent the car from falling.
8 other people completed this guide.
Shaun MacDonald
2,636 Reputation
8 Guides authored
Cal Poly, Team 24-27, Regan Fall 2012 Member of Cal Poly, Team 24-27, Regan Fall 2012
CPSU-REGAN-F12S24G27
4 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 48
Past 30 Days: 168
All Time: 42,850
