Trackpad Prereq
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Trackpad Prereq, Unfasten the trackpad: step 1, image 1 of 2 Trackpad Prereq, Unfasten the trackpad: step 1, image 2 of 2
    • Use a 5IP Torx Plus driver to remove the 13 screws securing the trackpad assembly:
    • Ten 5 mm screws
    • Three 5.8 mm screws
    • These screws all look similar—be careful not to mix them up.
    • Adding a little blue threadlocker to the screw threads during reassembly can help prevent the screws from working themselves loose over time.
    • Install the screws loosely at first, and then check the trackpad alignment before tightening them down.
  2. Trackpad Prereq, Remove the trackpad: step 2, image 1 of 3 Trackpad Prereq, Remove the trackpad: step 2, image 2 of 3 Trackpad Prereq, Remove the trackpad: step 2, image 3 of 3
    • Swing the display open slightly, but keep the MacBook upside-down. The trackpad assembly should separate and lay flat on the display.
    • As you remove the trackpad assembly, be very careful not to lose the nine small metal washers resting on the screw posts. (They will fly off and get lost with very little provocation.)
    • Carefully feed the trackpad's ribbon cable through its slot in the frame.
  3. Trackpad Prereq: step 3, image 1 of 1
    • Remove the trackpad assembly.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 16" Late 2023 Answers community for help.
Alex Diaz-Kokaisl
228,122 Reputation
1,106 Guides authored
iFixit Member of iFixit
Staff
124 Members
24,443 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 53
