Toshiba Satellite P55-A5312 Disassembly
  1. Toshiba Satellite P55-A5312 Disassembly, Toshiba Satellite P55-A5312 Disassembly: step 1, image 1 of 2 Toshiba Satellite P55-A5312 Disassembly, Toshiba Satellite P55-A5312 Disassembly: step 1, image 2 of 2
    • Locate all rubber plugs on the bottom of the laptop. These will need to be removed with a pointed object like the Spudger.
  2. Toshiba Satellite P55-A5312 Disassembly: step 2, image 1 of 1
    • After all rubber plugs are removed, use a Phillip's head screw driver to unscrew all previously covered screws.
  3. Toshiba Satellite P55-A5312 Disassembly: step 3, image 1 of 2 Toshiba Satellite P55-A5312 Disassembly: step 3, image 2 of 2
    • After all screws have been removed, pry the bottom cover of your laptop starting at the front edge.
    • Slowly work your way around the laptop until the back cover is completely off.
Jordan Kochavi
300 Reputation
2 Guides authored
Cal Poly, Team 9-1, Banghart Winter 2017 Member of Cal Poly, Team 9-1, Banghart Winter 2017
CPSU-BANGHART-W17S9G1
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 21
All Time: 4,864
