Table setting
  1. Table setting, Accessing the menu: step 1, image 1 of 3 Table setting, Accessing the menu: step 1, image 2 of 3 Table setting, Accessing the menu: step 1, image 3 of 3
    • With the machine on, go to the Quick Settings in the Home Menu.
    • Select the "Level Table" option.
    • Select "Home XYZ" so that the head goes to the starting position.
  2. Table setting, Adjustment positions: step 2, image 1 of 2 Table setting, Adjustment positions: step 2, image 2 of 2
    • The leveling should be performed on the 4 points of the table, as shown in the figure.
    • Select the "Set P1" option to level the table height at the first point.
  3. Table setting, Adjusting table height: step 3, image 1 of 3 Table setting, Adjusting table height: step 3, image 2 of 3 Table setting, Adjusting table height: step 3, image 3 of 3
    • The nozzle should be slightly away from the glass (thickness of a sulphite sheet).
    • To bring the table closer to the nozzle, turn the rosette clockwise.
    • To move the table away from the spout, rotate the rosette counterclockwise.
  4. Table setting, Adjustment of other points: step 4, image 1 of 3 Table setting, Adjustment of other points: step 4, image 2 of 3 Table setting, Adjustment of other points: step 4, image 3 of 3
    • Repeat the procedure for adjusting P1 for the other points.
Ready! Your table is level!
Special thanks to these translators:
pt en
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Mousta Impressoras 3D
691 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 10
All Time: 347
