RCA RCT6773W22 Battery Replacement
  1. RCA RCT6773W22 Battery Replacement, Battery: step 1, image 1 of 2 RCA RCT6773W22 Battery Replacement, Battery: step 1, image 2 of 2
    • Remove the two 5mm screws from the bottom of the device using a Phillips #000 screwdriver.
  2. RCA RCT6773W22 Battery Replacement: step 2, image 1 of 3 RCA RCT6773W22 Battery Replacement: step 2, image 2 of 3 RCA RCT6773W22 Battery Replacement: step 2, image 3 of 3
    • Place the plastic opening tool between the case and the screen.
    • Slide the tool clockwise around the case until all the clips are removed.
    • Do not completely separate the case from the screen because there is a wire connecting the motherboard to the speaker.
  3. RCA RCT6773W22 Battery Replacement: step 3, image 1 of 3 RCA RCT6773W22 Battery Replacement: step 3, image 2 of 3 RCA RCT6773W22 Battery Replacement: step 3, image 3 of 3
    • Desolder the two wires that connect the battery to the motherboard.
    • Learn more about soldering with this soldering technique guide.
    • Using the blue plastic opening tool, lift the battery away from the device.
2 other people completed this guide.
Kelsea Weber
19,889 Reputation
32 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,299 Guides authored
One Comment
Umm, which battery do you need for it? Seems that’s a part that is kind of important.
Cathy Hajo - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 27
All Time: 3,848
