Olympus Pen E-PL7 LCD Screen Replacement
  1. Olympus Pen E-PL7 LCD Screen Replacement, Battery: step 1, image 1 of 2 Olympus Pen E-PL7 LCD Screen Replacement, Battery: step 1, image 2 of 2
    • Turn the camera upside down.
    • Push the grey tab to the right to open the battery compartment.
    • Pull out the battery.
    • The battery is not shown in these photos.
  2. Olympus Pen E-PL7 LCD Screen Replacement, LCD Screen: step 2, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the three 2.3 mm screws from the base of the LCD screen.
  3. Olympus Pen E-PL7 LCD Screen Replacement: step 3, image 1 of 2 Olympus Pen E-PL7 LCD Screen Replacement: step 3, image 2 of 2
    • Fully extend the LCD assembly.
  4. Olympus Pen E-PL7 LCD Screen Replacement: step 4, image 1 of 3 Olympus Pen E-PL7 LCD Screen Replacement: step 4, image 2 of 3 Olympus Pen E-PL7 LCD Screen Replacement: step 4, image 3 of 3
    • Remove the two 2.2 mm Phillips screws located on the back of the LCD screen.
    • Use tweezers to remove the top LCD bracket.
  5. Olympus Pen E-PL7 LCD Screen Replacement: step 5, image 1 of 3 Olympus Pen E-PL7 LCD Screen Replacement: step 5, image 2 of 3 Olympus Pen E-PL7 LCD Screen Replacement: step 5, image 3 of 3
    • Use a Phillips #00 screwdriver to remove the four 1.4 mm screws from the back of the LCD screen.
    • Remove the LCD ribbon cable with a pair of tweezers.
    • The cover may fall off after the screws have been removed.
  6. Olympus Pen E-PL7 LCD Screen Replacement: step 6, image 1 of 3 Olympus Pen E-PL7 LCD Screen Replacement: step 6, image 2 of 3 Olympus Pen E-PL7 LCD Screen Replacement: step 6, image 3 of 3
    • Carefully lift the LCD screen up and away from the assembly.
    • Do not attempt to fully remove the screen, as it is attached to the assembly by a ribbon cable.
  7. Olympus Pen E-PL7 LCD Screen Replacement: step 7, image 1 of 2 Olympus Pen E-PL7 LCD Screen Replacement: step 7, image 2 of 2
    • Use tweezers to peel back the plastic cover.
  8. Olympus Pen E-PL7 LCD Screen Replacement: step 8, image 1 of 3 Olympus Pen E-PL7 LCD Screen Replacement: step 8, image 2 of 3 Olympus Pen E-PL7 LCD Screen Replacement: step 8, image 3 of 3
    • Use a spudger to flip back the black bar on the LCD Ribbon ZIF connector.
  9. Olympus Pen E-PL7 LCD Screen Replacement: step 9, image 1 of 2 Olympus Pen E-PL7 LCD Screen Replacement: step 9, image 2 of 2
    • Gently pull the ribbon cable out with tweezers.
  10. Olympus Pen E-PL7 LCD Screen Replacement: step 10, image 1 of 1
    • Remove the LCD Screen.
6 other people completed this guide.
Kelsea Weber
19,877 Reputation
32 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,198 Guides authored
7 Comments
Magnifico
Great Work!!
apuntotres - Reply
Where can I buy a replacement LCD screen?
Joshua Almeida - Reply
You don't show the final part taking the glass away from outer and the board, as the screen replacements don't come with connector board
josollis - Reply
@josollis: Thanks for the hint! I got the missing info from the E-P5 LCD exchange instructions (on ifixit).
Stephan Fagerer - Reply
I have reassembled the unit after replacing the broken Ribbon, however my LCD images are inverted in normal mode not selfie mode. Do anyone know why ?
Thanks in advance
ah to lee - Reply
Past 24 Hours: 9
Past 7 Days: 33
Past 30 Days: 105
All Time: 9,873
