Introduction
This guide shows how to access the Nintendo 2DS screen for repair and cleaning purposes.
Hold the side panels of the device's case with your fingers and pull outward to remove them.
There are three ribbon cables which have already been unplugged in this picture, disconnect these before disassembling the device further.
Remove the 12 brass-colored Phillips screws securing the main board.
There are two additional screws located on the top rail. Remove these to fully remove the buttons and top rail.
There are two screws holding down the joystick base that must be removed. (Be careful of the ribbon cableāit stays connected!)
Hold the top panel with your fingers and pull away from the device to remove it.
Detach the 2 ribbon cables by lifting the black flip connectors that hold them.
Lift out the rectangular board seated in the face and lift out the white square which is the joystick motor (takes a little effort). Both stay attached to the motherboard.
On some models, you'll need to remove three more tiny ribbon cables at the bottom of the screen. They are secured by flip up connectors. BE GENTLE!
Holding the motherboard on either side, lift to remove it.
Grasp the screen firmly by a corner and lift it off of the front panel of the Nintendo 2DS.
77 other people completed this guide.
30 Comments
Camera ribbon cable is very brittle, be careful.
Thank you so much, Fina! You have done a fantastic job explaining each step incredibly well! I very much appreciate all of your efforts into skillfully describing the process of disassembling the 2DS. I was able to understand your instructions and thus was able to make a lucky kiddo super happy! Thanks again!
-Skye
what about a new screen?
Once you've removed your screen, what are you supposed to do with it to clean and/or repair?
