Introduction
Only replace speaker as a last measure, since getting to the speaker requires removal of parts that might not fit perfectly back together.
Remove twenty-four 6 mm Phillips #2 from all 6 sides.
Once the screws are removed, gently pull apart the frame.
Remove four 6 mm Phillips #2 screws that hold down the speaker to its plastic frame.
Almost done!
