Motorola Xoom Wifi Display Assembly Replacement
  1. Motorola Xoom Wifi Display Assembly Replacement, Back Cover Disassembly: step 1, image 1 of 2 Motorola Xoom Wifi Display Assembly Replacement, Back Cover Disassembly: step 1, image 2 of 2
    • There are two 6.6 mm screws that hold ports into place as well as the back panel. Remove these with a T5 Torx screwdriver.
  2. Motorola Xoom Wifi Display Assembly Replacement: step 2, image 1 of 2 Motorola Xoom Wifi Display Assembly Replacement: step 2, image 2 of 2
    • Apply light pressure with hand and slide the back plate till it stops in this position.
    • There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
    • As soon as the clips are released the back should slide off.
  3. Motorola Xoom Wifi Display Assembly Replacement: step 3, image 1 of 3 Motorola Xoom Wifi Display Assembly Replacement: step 3, image 2 of 3 Motorola Xoom Wifi Display Assembly Replacement: step 3, image 3 of 3
    • Remove last two 4.2 mm screws from the remaining back piece with a T5 Torx screwdriver.
    • Once both screws are taken out, lift the rest of the backing out of the way.
  4. Motorola Xoom Wifi Display Assembly Replacement, Battery: step 4, image 1 of 2 Motorola Xoom Wifi Display Assembly Replacement, Battery: step 4, image 2 of 2
    • Remove the two battery leads with a T-5 Torx screwdriver.
    • Grab the red and black wires with your fingers and gently lift to disconnect black wire connector from the motherboard.
  5. Motorola Xoom Wifi Display Assembly Replacement: step 5, image 1 of 2 Motorola Xoom Wifi Display Assembly Replacement: step 5, image 2 of 2
    • All that holds the battery in are twelve screws. Remove them with a T-6 Torx screwdriver.
    • The battery should lift out easily.
  6. Motorola Xoom Wifi Display Assembly Replacement, Speakers: step 6, image 1 of 2 Motorola Xoom Wifi Display Assembly Replacement, Speakers: step 6, image 2 of 2
    • Use a plastic opening tool to pop out the speaker. Make sure to carefully pull off the wire as well.
    • Replace speaker if necessary.
  7. Motorola Xoom Wifi Display Assembly Replacement, Back-Facing Camera: step 7, image 1 of 2 Motorola Xoom Wifi Display Assembly Replacement, Back-Facing Camera: step 7, image 2 of 2
    • Use a spudger or a fine tip to lift the black tab to a vertical position.
    • A spudger is needed to remove the plastic border around the camera.
  8. Motorola Xoom Wifi Display Assembly Replacement: step 8, image 1 of 2 Motorola Xoom Wifi Display Assembly Replacement: step 8, image 2 of 2
    • When lifting the camera out, be sure to pull the orange ribbon cable as well.
  9. Motorola Xoom Wifi Display Assembly Replacement, Motherboard: step 9, image 1 of 3 Motorola Xoom Wifi Display Assembly Replacement, Motherboard: step 9, image 2 of 3 Motorola Xoom Wifi Display Assembly Replacement, Motherboard: step 9, image 3 of 3
    • Take a plastic opening tool and carefully pry off the touch screen controller connection.
    • Be careful with the black cover under the connection.
  10. Motorola Xoom Wifi Display Assembly Replacement: step 10, image 1 of 3 Motorola Xoom Wifi Display Assembly Replacement: step 10, image 2 of 3 Motorola Xoom Wifi Display Assembly Replacement: step 10, image 3 of 3
    • There are two relay wires that must be disconnected.
    • Pull both relay wires out of their connection ports.
    • Make sure to flip up the small black tab before you pull out the wire.
  11. Motorola Xoom Wifi Display Assembly Replacement: step 11, image 1 of 2 Motorola Xoom Wifi Display Assembly Replacement: step 11, image 2 of 2
    • Using a plastic opener, lift the metal bar clasping the wire harness to the motherboard.
  12. Motorola Xoom Wifi Display Assembly Replacement: step 12, image 1 of 3 Motorola Xoom Wifi Display Assembly Replacement: step 12, image 2 of 3 Motorola Xoom Wifi Display Assembly Replacement: step 12, image 3 of 3
    • There are eight 3.5mm screws that hold the motherboard in. Use a T-5 Torx screwdriver to take the screws loose. These screws are outlined in a gold color on the motherboard.
    • Two gold colored screws with brackets are located in the orange circles. A T-5 Torx screwdriver is needed to take these 3.1mm screws.
    • Motherboard should lift out easily and completely.
  13. Motorola Xoom Wifi Display Assembly Replacement, Display Assembly: step 13, image 1 of 2 Motorola Xoom Wifi Display Assembly Replacement, Display Assembly: step 13, image 2 of 2
    • Using the T-6 Torx screwdriver, unscrew the 17 4mm screws along the edge of the screen frame.
  14. Motorola Xoom Wifi Display Assembly Replacement: step 14, image 1 of 2 Motorola Xoom Wifi Display Assembly Replacement: step 14, image 2 of 2
    • Take the small plastic opening tool and separate the front glass from the screen frame.
    • Unfold the glass and the frame flat on the table.
  15. Motorola Xoom Wifi Display Assembly Replacement: step 15, image 1 of 3 Motorola Xoom Wifi Display Assembly Replacement: step 15, image 2 of 3 Motorola Xoom Wifi Display Assembly Replacement: step 15, image 3 of 3
    • Using the T-5 Torx screwdriver, unscrew the 12 4.1mm screws along the edge of the screen.
    • Pull ribbon wire out of slot in the frame to pull the screen off of the frame.
5 other people completed this guide.
Andrew Mercier
532 Reputation
3 Guides authored
Cal Poly, Team 3-39, Maness Spring 2014 Member of Cal Poly, Team 3-39, Maness Spring 2014
CPSU-MANESS-S14S3G39
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,557
