MacBook Air 13" Mid 2013 Upper Case Replacement
  1. MacBook Air 13" Mid 2013 Upper Case Replacement, Lower Case: step 1, image 1 of 1
    Tool used on this step:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Buy
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  2. MacBook Air 13" Mid 2013 Upper Case Replacement: step 2, image 1 of 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Mid 2013 Upper Case Replacement, Battery Connector: step 3, image 1 of 2 MacBook Air 13" Mid 2013 Upper Case Replacement, Battery Connector: step 3, image 2 of 2
    • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
    • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
    • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
  4. MacBook Air 13" Mid 2013 Upper Case Replacement, I/O Board Cable: step 4, image 1 of 1
    • Use the flat end of a spudger to pry the I/O board cable connector up out of its socket on the I/O board.
  5. MacBook Air 13" Mid 2013 Upper Case Replacement: step 5, image 1 of 1
    • Carefully peel the I/O board cable from the adhesive securing it to the top of the fan.
    • During reassembly, make sure this cable is in the correct orientation. It will fit if reversed, but the laptop will not boot.
  6. MacBook Air 13" Mid 2013 Upper Case Replacement: step 6, image 1 of 2 MacBook Air 13" Mid 2013 Upper Case Replacement: step 6, image 2 of 2
    • The following connector has an especially deep socket. Use care when disconnecting it.
    • While gently pulling the I/O board cable upward near its connection to the logic board, use the flat end of a spudger to pry up on alternating sides of the connector to help "walk" it out of its socket.
    • Remove the I/O board cable.
  7. MacBook Air 13" Mid 2013 Upper Case Replacement, Fan: step 7, image 1 of 1
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  8. MacBook Air 13" Mid 2013 Upper Case Replacement: step 8, image 1 of 1
    • Peel the rubber gasket off the adhesive on the top of the fan.
  9. MacBook Air 13" Mid 2013 Upper Case Replacement: step 9, image 1 of 1
    • Remove the following three screws securing the fan to the upper case:
    • One 3.6 mm T5 Torx screw
    • One 2.7 mm T5 Torx screw
    • One 3.6 mm T5 Torx screw with a short head
  10. MacBook Air 13" Mid 2013 Upper Case Replacement: step 10, image 1 of 2 MacBook Air 13" Mid 2013 Upper Case Replacement: step 10, image 2 of 2
    • Lift the fan from the I/O board side and pull it free from the upper case.
    • Removing the fan will also disconnect the fan ribbon cable. Be careful not to snag it.
  11. MacBook Air 13" Mid 2013 Upper Case Replacement, I/O Board: step 11, image 1 of 1
    • Disconnect the I/O board by pulling its power cable away from its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the right edge of the Air.
  12. MacBook Air 13" Mid 2013 Upper Case Replacement: step 12, image 1 of 2 MacBook Air 13" Mid 2013 Upper Case Replacement: step 12, image 2 of 2
    • Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
    • Pry up from beneath the wires.
  13. MacBook Air 13" Mid 2013 Upper Case Replacement: step 13, image 1 of 2 MacBook Air 13" Mid 2013 Upper Case Replacement: step 13, image 2 of 2
    • Use the tip of a spudger to carefully flip up the retaining flap on the microphone ribbon cable ZIF socket.
    • Make sure you are flipping up the retaining flap, not the socket itself.
  14. MacBook Air 13" Mid 2013 Upper Case Replacement: step 14, image 1 of 1
    • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
  15. MacBook Air 13" Mid 2013 Upper Case Replacement: step 15, image 1 of 2 MacBook Air 13" Mid 2013 Upper Case Replacement: step 15, image 2 of 2
    • Gently de-route the camera cable from its notch on the I/O board and push it out of the way with the tip of a spudger.
  16. MacBook Air 13" Mid 2013 Upper Case Replacement: step 16, image 1 of 1
    • Lift the I/O board from the logic board side and pull it free from the upper case.
    • Removing the I/O board will also disconnect the microphone ribbon cable. Be careful not to snag it.
  17. MacBook Air 13" Mid 2013 Upper Case Replacement, Battery: step 17, image 1 of 1
    • Remove the following five screws securing the battery to the upper case:
    • Three 6.3 mm T5 Torx screws
    • Two 2.4 mm T5 Torx screws
  18. MacBook Air 13" Mid 2013 Upper Case Replacement: step 18, image 1 of 1
    • When handling the battery, avoid squeezing or touching the four exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
  19. MacBook Air 13" Mid 2013 Upper Case Replacement, Logic Board Assembly: step 19, image 1 of 2 MacBook Air 13" Mid 2013 Upper Case Replacement, Logic Board Assembly: step 19, image 2 of 2
    • Grab the plastic pull tab secured to the display data cable lock and rotate it towards the top side of the computer.
  20. MacBook Air 13" Mid 2013 Upper Case Replacement: step 20, image 1 of 2 MacBook Air 13" Mid 2013 Upper Case Replacement: step 20, image 2 of 2
    • Pull the display data cable connector straight away from its socket.
    • Make sure to pull the connector parallel to the logic board, do not lift straight up from its socket.
  21. MacBook Air 13" Mid 2013 Upper Case Replacement: step 21, image 1 of 2 MacBook Air 13" Mid 2013 Upper Case Replacement: step 21, image 2 of 2
    • Use the flat end of a spudger to pry both antenna cable connectors up and off their sockets on the AirPort/Bluetooth card.
  22. MacBook Air 13" Mid 2013 Upper Case Replacement: step 22, image 1 of 2 MacBook Air 13" Mid 2013 Upper Case Replacement: step 22, image 2 of 2
    • Disconnect the camera cable connector with the tip of a spudger.
    • Push first on one side of the connector, then on the other side to carefully "walk" it out of its socket.
    • Pull the camera cable parallel to the face of the I/O board toward the front edge of the Air to disconnect it from its socket.
    • Do not lift upward on this cable as you disconnect it, as its socket may break off the logic board.
  23. MacBook Air 13" Mid 2013 Upper Case Replacement: step 23, image 1 of 2 MacBook Air 13" Mid 2013 Upper Case Replacement: step 23, image 2 of 2
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
    • Pull the trackpad ribbon cable straight out of its socket toward the front edge of the Air.
  24. MacBook Air 13" Mid 2013 Upper Case Replacement: step 24, image 1 of 3 MacBook Air 13" Mid 2013 Upper Case Replacement: step 24, image 2 of 3 MacBook Air 13" Mid 2013 Upper Case Replacement: step 24, image 3 of 3
    • Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
    • Use your spudger to gently pull the keyboard backlight ribbon cable out of its socket.
  25. MacBook Air 13" Mid 2013 Upper Case Replacement: step 25, image 1 of 1
    • Use the flat end of a spudger to pry the right speaker cable connector up and out of its socket on the logic board.
    • It is recommended to pry up from beneath the cables.
  26. MacBook Air 13" Mid 2013 Upper Case Replacement: step 26, image 1 of 1
    • Remove the six 6.3 mm T5 Torx screws securing the logic board to the upper case.
    • On some models these may be 4.1 mm T5 Torx screws.
  27. MacBook Air 13" Mid 2013 Upper Case Replacement: step 27, image 1 of 1
    • Remove the inner two 4.9 mm T8 Torx screws securing the antenna cable retainer and left clutch hinge to the upper case.
  28. MacBook Air 13" Mid 2013 Upper Case Replacement: step 28, image 1 of 1
    • Push the antenna cable retainer away slightly and remove the 3 mm T5 Torx screw securing the end of the heat sink to the upper case.
  29. MacBook Air 13" Mid 2013 Upper Case Replacement: step 29, image 1 of 3 MacBook Air 13" Mid 2013 Upper Case Replacement: step 29, image 2 of 3 MacBook Air 13" Mid 2013 Upper Case Replacement: step 29, image 3 of 3
    • Slide the flat end of a spudger under the right speaker from the end nearest the hinge to the front edge of the Air to loosen the adhesive.
    • Remove the right speaker from the upper case.
  30. MacBook Air 13" Mid 2013 Upper Case Replacement: step 30, image 1 of 2 MacBook Air 13" Mid 2013 Upper Case Replacement: step 30, image 2 of 2
    • Carefully remove the logic board assembly from the upper case, minding any cables that may get caught.
    • During reassembly:
    • Keep loose cables clear of the board so they aren't caught under it.
    • Make sure the antenna cables are inserted into their respective notches, as highlighted in the second picture.
  31. MacBook Air 13" Mid 2013 Upper Case Replacement, Display Assembly: step 31, image 1 of 1
    • Remove the inner two 4.9 mm T8 Torx screws securing the right display hinge to the upper case.
    • Leaving the third screw in place for now will aid in rest of the procedure.
  32. MacBook Air 13" Mid 2013 Upper Case Replacement: step 32, image 1 of 1
    • Open the display so that it is perpendicular to the upper case and place it on a table as shown.
  33. MacBook Air 13" Mid 2013 Upper Case Replacement: step 33, image 1 of 1
    • While holding the Air steady, remove the remaining 4.9 mm T8 Torx screw from the display bracket.
  34. MacBook Air 13" Mid 2013 Upper Case Replacement: step 34, image 1 of 1
    • Flip the computer over so the last display screw is more easily accesible.
    • Before removing the final display screw, be sure to hold the display and upper case steady with your other hand. Failure to do so may allow the components to fall onto the table, causing potentially expensive damage.
    • Remove the last 4.9 mm T8 Torx screw securing the display to the upper case.
  35. MacBook Air 13" Mid 2013 Upper Case Replacement: step 35, image 1 of 3 MacBook Air 13" Mid 2013 Upper Case Replacement: step 35, image 2 of 3 MacBook Air 13" Mid 2013 Upper Case Replacement: step 35, image 3 of 3
    • Open the Air slowly until the hinges slide out of their notches.
    • Once the two display hinges have cleared the upper case, remove the display and set it aside.
  36. MacBook Air 13" Mid 2013 Upper Case Replacement, Upper Case: step 36, image 1 of 3 MacBook Air 13" Mid 2013 Upper Case Replacement, Upper Case: step 36, image 2 of 3 MacBook Air 13" Mid 2013 Upper Case Replacement, Upper Case: step 36, image 3 of 3
    • Use the flat end of a spudger to pry the left speaker off the adhesive securing it to the upper case.
    • Remove the left speaker from the upper case.
  37. MacBook Air 13" Mid 2013 Upper Case Replacement: step 37, image 1 of 3 MacBook Air 13" Mid 2013 Upper Case Replacement: step 37, image 2 of 3 MacBook Air 13" Mid 2013 Upper Case Replacement: step 37, image 3 of 3
    • Use the flat end of a spudger to pry the microphone off the adhesive securing it to the left side of the upper case.
    • If needed, apply a little heat from an iOpener or hairdryer to soften the adhesive.
    • Remove the microphone from the upper case.
  38. MacBook Air 13" Mid 2013 Upper Case Replacement, Upper Case: step 38, image 1 of 3 MacBook Air 13" Mid 2013 Upper Case Replacement, Upper Case: step 38, image 2 of 3 MacBook Air 13" Mid 2013 Upper Case Replacement, Upper Case: step 38, image 3 of 3
    • Pull the trackpad ribbon cable straight out of its socket toward the rear edge of the Air.
  39. MacBook Air 13" Mid 2013 Upper Case Replacement: step 39, image 1 of 2 MacBook Air 13" Mid 2013 Upper Case Replacement: step 39, image 2 of 2
    • While carefully lifting the keyboard ribbon cable with one hand, use the tip of a spudger or your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Pull the keyboard ribbon cable straight out of its socket toward the front edge of the Air.
  40. MacBook Air 13" Mid 2013 Upper Case Replacement: step 40, image 1 of 1
    • Remove the following seven screws:
    • Six 1.6 mm Phillips screws securing the trackpad to the upper case.
    • One 1.4 mm T5 Torx set screw from its tapped hole near the front edge of the upper case.
    • During reassembly, do not over-tighten the set screw, as the button will cease to click at a certain point. Adjust the set screw until the movable side of the trackpad has minimal play.
  41. MacBook Air 13" Mid 2013 Upper Case Replacement: step 41, image 1 of 3 MacBook Air 13" Mid 2013 Upper Case Replacement: step 41, image 2 of 3 MacBook Air 13" Mid 2013 Upper Case Replacement: step 41, image 3 of 3
    • Carefully lift the edge of the trackpad closest to the keyboard from its recess in the upper case by lifting it away from the brackets attached to the upper case.
    • Remove the trackpad from the upper case.
    • The upper case remains.
56 other people completed this guide.
9 Comments
Hello all,
Could someone confirm if a upper case with keyboard from A1466 mid 2012 will fit well in A1466 mid 2013?
Thanks!
Nikolay Petrov - Reply
Wondering the same thing here, any luck?
Pedro Tinajero -
Very helpful. Step 29 seems to duplicate step 17.
Jason Buchanan - Reply
Step 29 is taking out the speakers. Step 17 is taking out the battery.
mel -
what type of adhesive do you need to reattach all of the stuff that was pried off? Or do you not need one?
Chi Nguyen - Reply
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 95
All Time: 49,016
