Jazz UltraTab C1059-HL Speaker Replacement
  1. Jazz UltraTab C1059-HL Speaker Replacement, Speaker: step 1, image 1 of 2 Jazz UltraTab C1059-HL Speaker Replacement, Speaker: step 1, image 2 of 2
    • Start by removing the back panel.
    • Remove the 4 screws holding the device together: two on the left side, and two on the right side.
    • Using a metal spudger, carefully pry open the case.
    • With the screws gone, the case is held together with clips along the outside edge of the aluminum backplate.
    • Undoing these clips can take a bit of force. Be cautious not to damage the plastic edge of the device.
  2. Jazz UltraTab C1059-HL Speaker Replacement: step 2, image 1 of 1
    • Place the device on the table with the screen-side down.
  3. Jazz UltraTab C1059-HL Speaker Replacement: step 3, image 1 of 1
    • This is the Speaker.
    • Remove the two black screws.
  4. Jazz UltraTab C1059-HL Speaker Replacement: step 4, image 1 of 1
    • Remove black tape from the wires.
    • Keep this tape, you will need it for reassembly.
  5. Jazz UltraTab C1059-HL Speaker Replacement: step 5, image 1 of 1
    • Using a soldering iron, heat up the spot where the speaker wires connect to the mainboard.
    • Remove Speaker wires when the solder liquifies.
    • Remember to make note of where each wire is connected. When reinstalling the speaker, it is important that the wires are reattached to the same spot.
  6. Jazz UltraTab C1059-HL Speaker Replacement: step 6, image 1 of 1
    • Remove the speaker.
    • Replace the speaker by following these steps in reverse.
Tim Poe
361 Reputation
3 Guides authored
IUPUI, Team 1-3, Wilson Fall 2015 Member of IUPUI, Team 1-3, Wilson Fall 2015
IUPUI-WILSON-F15S1G3
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 95
