JBL Flip Battery Replacement
  1. JBL Flip Battery Replacement, JBL Flip disassembly: step 1, image 1 of 3 JBL Flip Battery Replacement, JBL Flip disassembly: step 1, image 2 of 3 JBL Flip Battery Replacement, JBL Flip disassembly: step 1, image 3 of 3
    • On the end with the buttons, remove the end cap using the flat head screwdriver to get between the rubber lining and the plastic.
    • After the cap is removed, unscrew the two 3.3mm screws using a size 1 ph screw driver.
  2. JBL Flip Battery Replacement: step 2, image 1 of 3 JBL Flip Battery Replacement: step 2, image 2 of 3 JBL Flip Battery Replacement: step 2, image 3 of 3
    • Unscrew four 3.3mm screws on each end of the JBL using a size 1 ph screw driver (8 screws total).
  3. JBL Flip Battery Replacement: step 3, image 1 of 3 JBL Flip Battery Replacement: step 3, image 2 of 3 JBL Flip Battery Replacement: step 3, image 3 of 3
    • Remove outermost white casing by gently lifting up on one side.
    • Remove two 5mm screws holding the silver back plate in place with a size 2 ph screw driver.
    • Gently lift up and remove the silver casing.
  4. JBL Flip Battery Replacement: step 4, image 1 of 1
    • Remove last white back plate to expose the back of the speaker cover.
  5. JBL Flip Battery Replacement: step 5, image 1 of 3 JBL Flip Battery Replacement: step 5, image 2 of 3 JBL Flip Battery Replacement: step 5, image 3 of 3
    • Pry the four tabs on each side of the speaker cover (8 tabs total).
    • Pry the two tabs on each end to remove the cover (4 tabs total).
    • Slide speaker out of metal speaker cover.
  6. JBL Flip Battery Replacement: step 6, image 1 of 3 JBL Flip Battery Replacement: step 6, image 2 of 3 JBL Flip Battery Replacement: step 6, image 3 of 3
    • Remove 5mm screw in the middle of the back of the device with a size 2 ph screw driver.
    • Unscrew the two 5mm screws on each side using a size 2 ph screwdriver.
    • Open the speaker.
  7. JBL Flip Battery Replacement, Battery: step 7, image 1 of 2 JBL Flip Battery Replacement, Battery: step 7, image 2 of 2
    • Slowly peel the motherboard away from the black glue on the underside.
    • Make sure the battery below the motherboard is turned off before proceeding.
  8. JBL Flip Battery Replacement: step 8, image 1 of 2 JBL Flip Battery Replacement: step 8, image 2 of 2
    • Push brown tab up and gently pull connector out.
  9. JBL Flip Battery Replacement: step 9, image 1 of 3 JBL Flip Battery Replacement: step 9, image 2 of 3 JBL Flip Battery Replacement: step 9, image 3 of 3
    • Remove the first two connectors on the underside of the motherboard.
  10. JBL Flip Battery Replacement: step 10, image 1 of 3 JBL Flip Battery Replacement: step 10, image 2 of 3 JBL Flip Battery Replacement: step 10, image 3 of 3
    • Remove last connector.
    • Remove battery and replace.
24 other people completed this guide.
Dillon
1,556 Reputation
5 Guides authored
52 Comments
Excellent tutorial. Very detailed and helpful pictures.
Do you know what the part number and where it can be purchased?
Thanks!
Li V Xi - Reply
I also want to know about the battery specs
ravimohansairam Krishna - Reply
https://www.youtube.com/watch?v=apF4qT3e...
Follow this video tutorial. this will help you definitely
danish -
Mine is not working anymore and I suspect that the battery is not charging. I´ve checked the battery and its code is AEC653055-2Pwith rating 3,7V 2000 mAh. It has 3 cables: red, yellow and black. I´ve used a voltage meetering to check if there some charge coming from and it had 4,0 VDC. So, probably the problem related to my device is with the battery, because it´s not charging. Anyone else had this same issue?
Marcio Michel - Reply
hey. i had the same problem with the battery of JBL flip. and i fixed it. Complete video tutorial is here :)
danish -
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 71
All Time: 102,519
