How to Fix a Stuck Quarter in a Candy Machine
  1. How to Fix a Stuck Quarter in a  Candy Machine, How to Fix a Stuck Quarter in a  Candy Machine: step 1, image 1 of 3 How to Fix a Stuck Quarter in a  Candy Machine, How to Fix a Stuck Quarter in a  Candy Machine: step 1, image 2 of 3 How to Fix a Stuck Quarter in a  Candy Machine, How to Fix a Stuck Quarter in a  Candy Machine: step 1, image 3 of 3
    • Remove the lid of the machine.
    • Remove candy from container and place aside in a bowl.
  2. How to Fix a Stuck Quarter in a  Candy Machine: step 2, image 1 of 3 How to Fix a Stuck Quarter in a  Candy Machine: step 2, image 2 of 3 How to Fix a Stuck Quarter in a  Candy Machine: step 2, image 3 of 3
    • Using a flathead screwdriver unscrew the four 10mm corner screws.
    • Remove the plastic container and set it aside.
  3. How to Fix a Stuck Quarter in a  Candy Machine: step 3, image 1 of 2 How to Fix a Stuck Quarter in a  Candy Machine: step 3, image 2 of 2
    • Using a Phillips #1 screwdriver remove the two 15mm screws that are marked in the photo.
  4. How to Fix a Stuck Quarter in a  Candy Machine: step 4, image 1 of 2 How to Fix a Stuck Quarter in a  Candy Machine: step 4, image 2 of 2
    • Remove the inner mechanisms by sliding them up and off the metal rod.
  5. How to Fix a Stuck Quarter in a  Candy Machine: step 5, image 1 of 2 How to Fix a Stuck Quarter in a  Candy Machine: step 5, image 2 of 2
    • Remove the metal top with both hands on the sides.
    • Lift up, sliding it up and off the metal rod.
  6. How to Fix a Stuck Quarter in a  Candy Machine: step 6, image 1 of 3 How to Fix a Stuck Quarter in a  Candy Machine: step 6, image 2 of 3 How to Fix a Stuck Quarter in a  Candy Machine: step 6, image 3 of 3
    • Now you can see into the inner mechanisms.
    • Locate the stuck quarter and try to remove it.
    • For better access, lift up the left hinge to release the entire mechanism.
  7. How to Fix a Stuck Quarter in a  Candy Machine: step 7, image 1 of 2 How to Fix a Stuck Quarter in a  Candy Machine: step 7, image 2 of 2
    • Remove the inner mechanism by pulling out one side before sliding out the whole mechanism.
  8. How to Fix a Stuck Quarter in a  Candy Machine: step 8, image 1 of 2 How to Fix a Stuck Quarter in a  Candy Machine: step 8, image 2 of 2
    • Find the stuck quarter in the mechanism.
    • Remove the quarter with your hands by simply pulling (use a plier if needed).
  9. How to Fix a Stuck Quarter in a  Candy Machine: step 9, image 1 of 2 How to Fix a Stuck Quarter in a  Candy Machine: step 9, image 2 of 2
    • Slide the mechanism back in, right side in first followed by left.
    • Lock the mechanism in place by sliding the hinge lock back down.
  10. How to Fix a Stuck Quarter in a  Candy Machine: step 10, image 1 of 2 How to Fix a Stuck Quarter in a  Candy Machine: step 10, image 2 of 2
    • Return the metal top by sliding it back down the metal rod.
    • To secure the metal top back into place pull it forward so it covers the front of the machine.
  11. How to Fix a Stuck Quarter in a  Candy Machine: step 11, image 1 of 3 How to Fix a Stuck Quarter in a  Candy Machine: step 11, image 2 of 3 How to Fix a Stuck Quarter in a  Candy Machine: step 11, image 3 of 3
    • Slide the rotation mechanism back down so it sits with one of the three holes is fully over the hole.
    • Slide down the cover mechanism so it aligns with the screw holes.
    • Use a phillips head screwdriver to screw down the two side screws.
  12. How to Fix a Stuck Quarter in a  Candy Machine: step 12, image 1 of 2 How to Fix a Stuck Quarter in a  Candy Machine: step 12, image 2 of 2
    • Replace the plastic container so it aligns with the four screw holes.
    • Replace the four screws using a flat head screwdriver.
  13. How to Fix a Stuck Quarter in a  Candy Machine: step 13, image 1 of 2 How to Fix a Stuck Quarter in a  Candy Machine: step 13, image 2 of 2
    • Replace the candy and the lid.
    • Enjoy your sweet tooth adventures.
I hope this guide helps you understand how to fix and change your candy machine, enjoy your candy!
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 26
All Time: 2,472
