Back Panel Disassembly
  1. Back Panel Disassembly, Back Panel Disassembly: step 1, image 1 of 2 Back Panel Disassembly, Back Panel Disassembly: step 1, image 2 of 2
    • With the battery door facing upward, take your PH000 screwdriver and remove the 4 mm screws from the bottom of the device.
  2. Back Panel Disassembly: step 2, image 1 of 2 Back Panel Disassembly: step 2, image 2 of 2
    • After removing the screws, rotate the device to where the micro USB port is facing up.
    • Now, take your PH000 screwdriver and remove the two 4 mm screws from the device.
  3. Back Panel Disassembly: step 3, image 1 of 2 Back Panel Disassembly: step 3, image 2 of 2
    • Rotate the device 180 degrees so that the opposite side of the device is now facing upwards.
  4. Back Panel Disassembly: step 4, image 1 of 2 Back Panel Disassembly: step 4, image 2 of 2
    • After all of the screws are removed, rotate the device so that the bottom of the device is now facing upward.
    • With your index finger, press down and slide open the memory card/battery door.
  5. Back Panel Disassembly: step 5, image 1 of 3 Back Panel Disassembly: step 5, image 2 of 3 Back Panel Disassembly: step 5, image 3 of 3
    • Now take the plastic opening tool, and place it in the seam of the device.
    • Now, work the tool around the seam of the device until you can safely pry open the device.
  6. Back Panel Disassembly: step 6, image 1 of 2 Back Panel Disassembly: step 6, image 2 of 2
    • Be careful when removing the back piece of your device.
    • Using your free hand, finish prying off the back piece of the device.
2 other people completed this guide.
Jordan Rosemeyer
491 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 31
All Time: 906
