ASUS UX50V-RX05 Keyboard Replacement
  1. ASUS UX50V-RX05 Keyboard Replacement, Keyboard: step 1, image 1 of 3 ASUS UX50V-RX05 Keyboard Replacement, Keyboard: step 1, image 2 of 3 ASUS UX50V-RX05 Keyboard Replacement, Keyboard: step 1, image 3 of 3
    • Make sure the device is powered off and the battery is removed before beginning.
    • Use the Plastic Opening tool to pry the five slots up at the top of the keyboard.
  2. ASUS UX50V-RX05 Keyboard Replacement: step 2, image 1 of 2 ASUS UX50V-RX05 Keyboard Replacement: step 2, image 2 of 2
    • Lift the keyboard enough to expose the two ribbon connectors (LCD flex cable and flex band).
    • Use the Plastic Opening tool to push open the two black clips on each side of the connecting cords.
    • Remove the cable after pushing out the two black clips.
  3. ASUS UX50V-RX05 Keyboard Replacement: step 3, image 1 of 2 ASUS UX50V-RX05 Keyboard Replacement: step 3, image 2 of 2
    • Push out each end of the black clip with a plastic opening tool or nylon spudger to remove the ribbon cable.
    • Remove the cable after pushing out both black clips.
    • Remove the keyboard.
James
663 Reputation
6 Guides authored
USF Tampa, Team 20-2, Remmell Spring 2017 Member of USF Tampa, Team 20-2, Remmell Spring 2017
USFT-REMMELL-S17S20G2
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 19
All Time: 524
