1998-2002 Honda Accord Ignition Switch Replacement
  1. 1998-2002 Honda Accord Ignition Switch Replacement, Ignition Switch: step 1, image 1 of 1
    • The tools and materials you will need:
    • 10 mm Wrench
    • Phillips Screwdriver
    • Flathead Screwdriver
    • Electrical Tape
    • Multimeter (not shown)
    • Electrical portion of the Honda Accord ignition switch
  2. 1998-2002 Honda Accord Ignition Switch Replacement: step 2, image 1 of 1
    • Disconnect the battery. This is especially important because you're going to be working near the airbag.
    • Do not touch any yellow wires under the dash -- they're for the airbag (or so I've heard).
    • As you can see, I keep my battery in tip-top shape. The grime acts as a blanket layer of protection against the elements.
  3. 1998-2002 Honda Accord Ignition Switch Replacement: step 3, image 1 of 1
    • Remove the driver's side fuse panel cover.
  4. 1998-2002 Honda Accord Ignition Switch Replacement: step 4, image 1 of 2 1998-2002 Honda Accord Ignition Switch Replacement: step 4, image 2 of 2
    • Remove the two Phillips retaining screws that hold the driver's side lower panel to the dash.
  5. 1998-2002 Honda Accord Ignition Switch Replacement: step 5, image 1 of 2 1998-2002 Honda Accord Ignition Switch Replacement: step 5, image 2 of 2
    • Use a flathead screwdriver to pry off the left side of the panel immediately below the radio surround.
  6. 1998-2002 Honda Accord Ignition Switch Replacement: step 6, image 1 of 1
    • Remove the last Phillips screw securing the right side of the driver's side lower panel.
  7. 1998-2002 Honda Accord Ignition Switch Replacement: step 7, image 1 of 2 1998-2002 Honda Accord Ignition Switch Replacement: step 7, image 2 of 2
    • Now the driver's side lower panel can be removed. Begin on the left side and gently pull it off, so that all of the retaining clips are released.
  8. 1998-2002 Honda Accord Ignition Switch Replacement: step 8, image 1 of 1
    • The ignition switch can now be unplugged for testing. The switch connects to the rear of the driver's side fuse panel. Shine a flashlight and find the connector highlighted in red.
  9. 1998-2002 Honda Accord Ignition Switch Replacement: step 9, image 1 of 3 1998-2002 Honda Accord Ignition Switch Replacement: step 9, image 2 of 3 1998-2002 Honda Accord Ignition Switch Replacement: step 9, image 3 of 3
    • Users are reporting a variation of the ignition switch positions on the pictured diagram that corresponds to these numbers:
    • LOCK: All Open | ACC: 1 + 5 | ON: 1+3+4+5 | START 1+2+3
    • Now it's testing time. The key should be placed into the ignition switch and turned to the appropriate position; you should test for continuity between each of the points as outlined in the guide.
    • I want to mention that this testing should be performed as thoroughly as possible, since the switch may appear to be fine at first. I got lucky in the sense that the switch immediately failed one of the tests. The best way to test the switch is to plug in the multimeter leads into the 1 and 4 terminals, and then to cycle between "On" and "Start." Eventually the multimeter should read "no continuity" in the "On" position, indicating that the switch is bad.
  10. 1998-2002 Honda Accord Ignition Switch Replacement: step 10, image 1 of 1
    • Of course proceed at this point only if the switch failed one of the continuity tests. Also, make sure that the ignition switch is in the "Lock" position before proceeding any further.
    • Lower the steering wheel adjustment lever all the way down.
  11. 1998-2002 Honda Accord Ignition Switch Replacement: step 11, image 1 of 2 1998-2002 Honda Accord Ignition Switch Replacement: step 11, image 2 of 2
    • Remove the three Phillips screws on the lower steering column cover.
    • Pop the lower steering column cover off the top cover, giving you access to the electrical portion of the ignition switch.
  12. 1998-2002 Honda Accord Ignition Switch Replacement: step 12, image 1 of 1
    • While in the general ignition switch area, make sure not to touch the steering column adjustment grease. I found it to be very greasy, as grease should be.
  13. 1998-2002 Honda Accord Ignition Switch Replacement: step 13, image 1 of 2 1998-2002 Honda Accord Ignition Switch Replacement: step 13, image 2 of 2
    • Unscrew the two Phillips screws that hold the ignition switch cover (and switch itself) in place.
  14. 1998-2002 Honda Accord Ignition Switch Replacement: step 14, image 1 of 1
    • The cover should be loose on the switch, however there is another screw holding it in place behind the steering wheel.
    • I found this screw by feeling around for it after realizing the cover was still held in place by something. It was not completely necessary to remove this screw to replace the switch, so I'll leave it up to you whether or not you want to remove it. The screw is in such a difficult place that I figured it would be harder to screw it back in place after removing it than just bending the ignition switch cover backwards and removing the switch.
    • Other users have partially broken the cover since they did not fully remove the third screw. You've been warned.
  15. 1998-2002 Honda Accord Ignition Switch Replacement: step 15, image 1 of 1
    • Gently rotate the black cover aside and pull out the ignition switch.
  16. 1998-2002 Honda Accord Ignition Switch Replacement: step 16, image 1 of 1
    • At this point you can test the new switch for continuity, just to make sure it's 100% functional before putting it into the car. Follow the same steps outlined in step #7 except use the flat blade screwdriver to switch between ignition positions. You'll notice that the switch clicks just like it does when you insert your key into the steering column ignition. If the continuity tests pass, you can proceed with installing it into your car.
    • Once you remove the old switch from its cover, plug in the new switch connector into the rear of the fuse panel and connect the other side to the steering column.
    • Make sure that the new switch is in the "Lock" position. To make sure it is in the "Lock" position, use the flat blade screwdriver to gently twist the switch counter-clockwise until it will twist no more, ensuring that the switch is in the "Lock" position.
  17. 1998-2002 Honda Accord Ignition Switch Replacement: step 17, image 1 of 2 1998-2002 Honda Accord Ignition Switch Replacement: step 17, image 2 of 2
    • Route the wiring in the same manner the old switch wiring was routed, insert the switch into the steering column, and put back the ignition switch cover and screws.
    • Use the electrical tape to corral any of the loose wiring. Put all paneling back the way it was by following the above directions in reverse. Make sure that the rubber O-ring around the ignition switch is properly seated against the switch when putting back the lower steering wheel cover.
52 other people completed this guide.
47 Comments
Installed an autoparts store ignition switch using this guide. Unfortunately, the engine wouldn't start. Electronics worked fine, but got absolutely nothing when I tried to crank the car. No ignition, let alone engine turn over. So, basically nothing... no sound or anything. Just the key turning in the ignition. Almost as if the anti-theft had kicked in. However, the immobilizer indicator didn't come on, so I'm ruling that out. Maybe it was a bad switch, right out of the box. Again, had to take it out and put the old one back in. The car fired right up. Anyone else experience that?
kenneth smith - Reply
That's really strange, Kenneth. I replaced my failing ignition switch with a dealer part, and didn't encounter any such difficulty.
I can't say for sure -- I'm no Honda expert by any means -- but it could be that the original switch has some additional safety/anti-theft feature that the non-OEM lacks, preventing the non-OEM from working properly. However, I'm pretty sure I've heard that other folks installed auto-parts store switches and they worked just fine.
Miroslav Djuric -
Well i just bought a swith and all new ignition and installed it and had the same result. Turns over and nothing else. Everything turns on but it wont start
lawleew37 -
i actually just want to thank you for posting this on cus i just bought a 98 honda accord and already had put $1000 to fix it in it already. then it was going to cost me $300 to get a mechanic to do it. I found this and my dad and I did it together and only had to pay $57 for the part and hour of our time to do it. So thank you very much in saving that much money. Now my car runs fine again and hopefully i dont have to deal with it dying anymore. Heather F. Pueblo, Co
Heather - Reply
I got the part at Autozone for 57...and it took me literally 15 mins to do...just because I had gone over this. So when it came down to it, it was so easy. Thank you for your time and kindness to post this up. =)
Jen - Reply
Past 24 Hours: 16
Past 7 Days: 140
Past 30 Days: 602
All Time: 244,534
