Google Home Is Not Responding
Gabe Hyun and 1 contributor
Last updated on
Causes
Move location of device away from other appliances or obstructions. Make sure your Google home is in a quiet location and try speaking loudly and clearly.
2
The microphone of your Google home may be muted (if this is the case there will be four still, orange lights in a diamond). To unmute your Google Home press the button on the back of the speaker.
3
Try restarting your device. Open Google Home app and select the device you are trying to reboot. Go to Settings (three vertical dots in the upper right corner of the device card) and tap More and then Reboot.
or
Unplug the device for roughly a minute, and then it plug back into the power source. Allow the device to reboot itself.
4
Go to myactivity.google.com and listen to the voice recordings that your device is picking up. If you hear static or bad quality recordings contact Google Home Support. The "Contact Us" option will be in the upper right hand corner of this page.
5
Your Google Home may need a complete reset to default factory settings in order to fix the issue. This action cannot be undone and you’ll need to set up the device again.
If nothing else is working: press and hold the mute button on the back of your Google Home for about 15 seconds. You'll hear your Google Assistant confirm that it's resetting Google Home.
View statistics:
Past 24 Hours:
3
Past 7 Days:
10
Past 30 Days:
60
All Time:
668
