Vizio Co-Star Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
It's been nearly two years since Google unveiled its flop of a streaming media player, the Logitech Revue. After a lengthy hiatus from the spotlight, Google TV is back to take the stage. Its lead actor? The ironically-named Vizio Coaster Co-Star.
Want to keep up with all of our latest teardowns? Follow @ifixit on Twitter!
Image #1
Add Note Edit Step 1 — Vizio Co-Star Teardown  ¶
  • Providing the market with a $99 answer to the Apple TV (also $99), the Vizio Co-Star brings a refreshing reincarnation of Google TV to the world of set-top boxes.
  • Notable tech specs:
    • Google TV platform
    • Wi-Fi and Bluetooth enabled
    • Hot buttons for Amazon, Netflix, and M-Go
    • 720p, 1080i, and 1080p resolution support
    • MP3, AAC, and WMA audio playback
    • Universal QWERTY remote with trackpad
Image #1 Image #2
Add Note Edit Step 2  ¶
  • The rear side of the Vizio Co-Star includes an impressive lineup:
    • USB 2.0 port
    • HDMI-In port
    • HDMI-Out port
    • Ethernet port
    • DC-In Power port
  • On the bottom we see the reset switch and four suspicious-looking rubber feet.
Image #1 Image #2
Add Note Edit Step 3  ¶
  • A little prying around the edge with a plastic opening tool, and we've got the bottom panel free.
  • Comparatively speaking, the Apple TV required two metal spudgers to open, as opposed to a single plastic opening tool here. No need to split hairs; they're both easy to open up, and we love it.
Image #1 Image #2
Add Note Edit Step 4  ¶
  • We pull off what looks like an EMI shield only to find a thermal pad sitting on top of a sea of small resistors.
  • It's not often that we encounter cooling for the back side of a motherboard, but Vizio took extra precautions as this Co-Star has no fans.
Image #1 Image #2 Image #3
Add Note Edit Step 5  ¶
  • The only thing standing between us and the motherboard are some screws and two connectors. Say hello to our little friend!
  • For those of you tuning in at home, a grand total of five screws and two cables must be removed once inside the device to free the motherboard. That's going to give the Co-Star a nice ratings boost.
Image #1 Image #2
Add Note Edit Step 6  ¶
  • And here comes the Co-Star's motherboard strolling down the red carpet:
Image #1 Image #2
Add Note Edit Step 7  ¶
  • We're used to the innards of devices being dominated by a single component, but those space hogs are usually batteries or power supplies.
    • Over a third of the real estate in the Co-Star is inhabited by the aluminum heat sink.
  • You may be asking yourself why the Co-Star has such a huge heat sink?
  • The answer lies in air movement. Without fans to circulate air, there is no forced convection. Therefore, the Co-Star must rely on conduction and natural convection to keep the processor cool.
Add Note Edit Step 8  ¶
  • We remove an additional board to reveal a whole lot of nothin' underneath.
  • The board houses the USB port and, well, nothing else.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
iFixit Guitar Picks set of 6
$6.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 24 In stock
Inspection Scope
$39.95 · 39 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 17 In stock
Popular Products
iPhone 4S Rear Glass Panel
$44.95 · 50+ In stock
iPad 4th Gen Front Panel Assembly
$134.95 · 32 In stock
Heavy-duty Suction Cups (Pair)
$14.95 · 50+ In stock
Anti-Static Mat
$24.95 · 50+ In stock
