Image #1 Image #2 Image #3
Add Note Edit Step 9  ¶
  • While it may appear as though the battery in the Note 10.1 is strapped down à la Gulliver, the ribbon cables are very easy to detach.
  • In fact, the battery is very easy to remove, even when compared to the Nexus 7.
Image #1
Add Note Edit Step 10  ¶
  • Just like in the new iPad, the battery in the Note accounts for a large portion of the device's weight. It weighs in at 136 grams. That's 23 percent of the 594 gram device.
    • Still, in order to keep this device so slim, we have a feeling the battery capacity had to take a hit.
  • The battery is rated at 3.7 volts, 7000 mAh, and 25.90 watt-hours.
  • The battery was downsized to 25.90 watt-hours for an estimated battery life of 8 hours. As expected, the battery falls short of the new iPad's 42.5 watt-hour battery and 10 hour battery life.
Image #1 Image #2
Add Note Edit Step 11  ¶
  • We happily detach the last of the ribbon cables connected to the motherboard and pull it free from the Note. Well, that was easy!
Image #1 Image #2
Add Note Edit Step 12  ¶
  • Sometimes EMI shields can be scary/tricky to remove, depending on which procedure a manufacturer uses to attach them to the motherboard. In some cases, the shields are soldered directly to the motherboard (the worst scenario), while in others the frames of the shields are soldered, but the top covers are removable.
  • …Unless EMI shields happen to be screwed in, as is the case here. We love screws, especially when they hold in components that typically require desoldering.
    • This is the first device we've seen with screwable EMI shields. Props to you, Samsung.
Image #1 Image #2
Add Note Edit Step 13  ¶
  • In addition to protecting important components of the motherboard from electromagnetic interference, it appears that these EMI shields also serve as the Note's heat sinks.
  • The green film on the insides of the EMI shields holds thermal paste and thermal pads in place, which help move heat away from the motherboard through small holes in the tops of the shields.
Image #1
Add Note Edit Step 14  ¶
  • There are some major players on this motherboard:
  • Board too small to see? No worries, we got you covered.
Add Note Edit Step 15  ¶
  • Just like all of the components that we disconnected in the first few steps, the dock connector can be removed by simply detaching a connector and unscrewing a pair of screws. More points for repairability!
  • Samsung's dock connector cable shares a bit of copper with the lower microphone.
  • As a reminder, the Samsung dock connector is not the same as Apple's dock connector, as shown by this image.
Add Note Edit Step 16  ¶
  • At this point, it appears that there are no more screws left to remove from the device.
  • The speakers were held in place with some light adhesive, which we spudged right up!
  • The speakers in the Note 10.1 probably won't shatter any glasses, but they certainly do a good job of playing pleasant bubble noises as you navigate the Note's interface.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Plastic Opening Tools
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
Inspection Scope
$39.95 · 17 In stock
Portable Anti-Static Mat
$24.95 · 10 In stock
Popular Products
Heavy-duty Spudger
$4.95 · 48 In stock
Metal Spudger Set
$7.95 · 50+ In stock
54 Bit Driver Kit
$24.95 · 50+ In stock
T5 Torx Screwdriver
$6.95 · 26 In stock
Helping Hands
$8.95 · 16 In stock
