Image #1
Add Note Edit Step 33 — CPU Heatsink  ¶
  • Now, remove these three Phillips screws:
  • As there are two Phillips screws well, there are two that you can see in the photo, but you want to remove the screws that are behind them.
Image #1 Image #2
Add Note Edit Step 34  ¶
  • Now, lift the heatsink up off the computer, it is pretty heavy, because it's a giant block of aluminum.
  • Be careful when holding it, the edges can be sharp, making it likely to get cut if you hold it wrong!
  • As you may be able to tell, i have applied a replacement coat of Arctic Silver 5 to keep my MDD cooler than the stock paste, it really does a great job too!
Image #1 Image #2
Add Note Edit Step 35  ¶
  • The incredibly large heatsink, this thing is 5 Lbs of solid aluminum. Just like every other part in this, and many other Macs, the heatsink is made by: ...you guessed it, Foxconn.
Image #1 Image #2 Image #3
Add Note Edit Step 36 — Powermac G4 MDD (Mirrored Drive Doors) Teardown  ¶
  • The Powermac G4 MDD's, Guts Spilled On My Desk:
Image #1
Add Note Edit Step 37  ¶
  • The PowerMac G4 MDD Complete With Pro Speakers, 17" Studio Display, Mighty Mouse And Keyboard, Runs Leopard Server and Ubuntu 9 Beautifully.
Next » « Previous
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ In stock
1.5mm Hex Screwdriver
$9.95 · 4 In stock
Related Products
Airport Card
$49.95 · 5 In stock
Airport Extreme Card
$29.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
iFixit Lock Pick Set
$29.95 · 9 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
