Nintendo Family Computer (Famicom) Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
It's day four of our week of game console teardowns. We stole borrowed a hot tub time machine, went directly to 1983, and acquired a Japanese national treasure: the Famicom!
We partnered with Wired for this teardown to bring you a glimpse of one of the most popular game consoles ever. Check out their story!
For those of you born in this century, the Famicom -- short for Family Computer -- is the name of the Nintendo Entertainment System (NES) in Japan. Join us as we delve into the system that revolutionized the gaming world as we know it.
Image #1 Image #2
Add Note Edit Step 1 — Nintendo Family Computer (Famicom) Teardown  ¶
  • Our contestant hails from a mystical place, the land of the rising sun, Japan!
  • The Nintendo Family Computer, released in 1983 in most of Asia, is the overseas brother of the Nintendo Entertainment System.
  • Technical Specifications:
    • Ricoh 2A03 8-bit 1.79 MHz processor (based on the MOS Technology 6502 8-bit processor core)
    • 2KB (16Kb) on-board RAM
    • 2KB (16Kb) on-board Video RAM
    • PSG Sound
    • 256 x 240 pixels resolution
Image #1 Image #2
Add Note Edit Step 2  ¶
  • Backside ports include:
    • AC adapter port
    • TV/Game switch
    • Channel selector switch
    • RF Audio/Video output
  • Why are you looking so scared, little buddy? Don't worry -- our hands are gentle. We won't hurt you.
Image #1 Image #2
Add Note Edit Step 3  ¶
  • Fully assembled Nintendo Famicom console.
  • The Famicom was the first console to popularize D-pad controllers to acquire user input. Departing from the era of joysticks, the inclusion of the D-pad allowed for quick and accurate controls.
  • The controllers are similar, but not the same...
    • The first controller boasts the traditional layout: D-pad on the left, "select" and "start" buttons in the center, and "b" and "a" buttons on the right.
    • However, the second controller has a built-in microphone and a volume switch at the expense of the central "select" and "start" buttons... Cool!
    • This is the only console we know of that has a microphone on one of its standard controllers.
Image #1
Add Note Edit Step 4  ¶
  • The Famicom's miniscule 4W power supply won't be popping fuses anytime soon.
    • That's about 2.5% of the power that the Xbox 360 devours.
  • Nintendo Famicom model number HVC-001, Made in Japan. We wouldn't want our Famicom any other way.
Image #1 Image #2
Add Note Edit Step 5  ¶
  • A quick removal of six Phillips screws and the bottom cover lifts right off.
  • Just like the earlier retro consoles, Fami is super-easy to disassemble.
  • (yes, we named him Fami.)
Image #1 Image #2 Image #3
Add Note Edit Step 6  ¶
  • Two antiquated connectors exchange signals between the controllers and the board.
    • Want to disconnect a controller? Gotta remove the bottom cover -- but that's pretty much it.
  • Controller II has an extra wire for microphone input and controlling the volume.
  • After disconnecting them from the board, the controller cables can be lifted out of the case.
Add Note Edit Step 7  ¶
  • Six Phillips screws secure the motherboard assembly to the outer case.
  • Lifting the assembly out of the case gives us a good look at the archaic silicon that makes this thing tick.
  • Two more Phillips screws secure the hefty power switch to the outer case.
Image #1 Image #2
Add Note Edit Step 8  ¶
  • Notable chips on the board include:
    • Ricoh RP2A03G 8-bit, 1.79 MHz CPU
    • Ricoh RP2C02G-0 8-bit, 5.32 MHz PPU
    • Toshiba TC40H368P hex bus buffers
    • Sharp LH5216D-12 static RAM
    • Hitachi HD74LS139P decoder/demultiplexer
    • Fujitsu MB74LS373
  • Unsurprisingly, lead solder abounds on the bottom of the board. RoHS standards weren't established until 20 years after this puppy was made.
Next » « Previous
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 13 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
Popular Products
iPhone 3G and 3GS Mute Button
Magnetizer/Demagnetizer
Tri-point Y0 Screwdriver
$9.95 · 21 In stock
Helping Hands
$8.95 · 50+ In stock
