NeXTStation Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Add Note x
NeXT Computer was founded in 1989 by Steve Jobs when he was forced out of Apple by John Scully. He started NeXT as a high-end computer company targeted at the University/Scientist/Computing Industry. NeXT only ever released two major computers, the NeXTStation, and The NeXTCube, in different variations. NeXT computers were high-end workstation computers, and only a few thousand were ever sold. The NeXTStation featured a 25Mhz Motorola 68040 CPU, though the Turbo NeXTStation featured a 33Mhz 68040. There were color and non-color variations of the NeXTStation. The world's first web server was created by Tim Berners-Lee, at CERN on a NeXTCube. NeXT computers were used to make games like Doom, and Wolfenstein. This is my 25Mhz B&W NeXTStation. Mac OS X Is based off of NeXTStep, the NeXT OS.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 1 — NeXTStation Teardown  ¶
  • The NeXTStation, this is a great addition to any computer collection.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 2  ¶
  • Turn the NeXTStation around, and remove this screw:
  • Then, lift the top cover of the computer. This will reveal the guts.
  • The ports from left to right: SCSI2, Keyboard & Mouse, DSP Port, DB-19(MegaPixel Display), DB-9(Serial), RJ-45(Ethernet), Coaxial (10b2 Ethernet), Power
  • I find notes in everything!
first image
thumb image 1
thumb image 2
Add Note Edit Step 3  ¶
  • Removing the hard drive:
  • The NeXTStation uses a 50-Pin SCSI Hard Drive up to 4GB.
  • Remove all of the cables from the logic board.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 4  ¶
  • Then remove this screw.
  • Once the screw is removed, pivot the drive up on a 45 Degree angle, then slide it out.
first image
Add Note Edit Step 5  ¶
  • The Hard Drive & Caddy
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 6  ¶
  • Removing the floppy disk drive:
  • The NeXTStation uses a non-standard 2.88MB 3.5" floppy drive, though it uses the standard floppy connector.
  • Remove the floppy cable.
  • Then, remove this screw.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 7  ¶
  • Then, just like the hard drive, pivot the drive up 45 degrees, and pull it out.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 8  ¶
  • Removing the fan:
  • Remove this connector.
  • Remove these screws.
  • Remove the fan.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 9  ¶
  • Removing the logic board:
  • Remove the power supply connector. Just lift it straight up, and it should come free.
  • remove this screw.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 10  ¶
  • Lift the end of the logic board(away from the ports), and slide it away from the ports.
  • Now, set the board aside.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 11  ¶
  • Power Supply:
  • Remove this screw.
  • Lift the power supply up, and out.
first image
Add Note Edit Step 12  ¶
  • The Logic Board Overview:
  • The Board has a 25Mhz Motorola 68040 CPU, This board features a ton of chips for somthing made nearly 20 years ago.
  • The CPU: Motorola XC68040RC25
  • The Co-Procesor: MB610313
  • Motorola Chips
  • Intel Chips
  • AMD Chips (Intel and AMD In the same computer?)
  • Fujitsu Chips
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 13  ¶
  • Made in the USA, you don't see this anymore.
  • The Serial #
  • Looks like my NeXTStation came from WilTel.
  • It is model # N1100
Required Tools
Phillips #0 Screwdriver
$4.95 · 50+ in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 21 in stock
Sorting Tray
$7.95 · 15 in stock
Anti-Static Wrist Strap
$7.95 · 50+ in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$9.95 · 50+ in stock
Popular Products
iPhone 4S Display Assembly
$129.95 · 49 in stock
1.5" Thin Putty Knife
$6.95 · 28 in stock
Anti-Static Mat
$24.95 · 50+ in stock
Precision Tweezers Set
$7.95 · 41 in stock
Dust Blower
