first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 9  ¶
  • Kinect's slim form factor has forced Microsoft to split up the main board, stacking three boards vertically like a small apartment building.
  • There's a fan at the far end of the Kinect. It's aligned to suck air in one side of the Kinect and push it out the other.
first image
Add Note Edit Step 10  ¶
  • We've finally found the Kinect's eyes.
  • Two cameras and an IR projector.
    • Left: (IR CMOS) Microsoft / X853750001 / VCA379C7130
    • Center: (Color CMOS) VNA38209015
    • Right: (IR Projector) OG12 / 0956 / D306 / JG05A
  • This picture is of the device upside down, so these labels are swapped from what you would see looking at the Kinect.
  • These are not tiny, cell-phone cameras— they're closer to the camera you might find in a webcam, with large lenses and autofocus.
  • We can't independently confirm the resolution of the cameras yet, but Microsoft claims that the infrared cam is 320x240 and the RGB cam is 640x480.
first image
thumb image 1
thumb image 2
Add Note Edit Step 11  ¶
  • This is a Prime Sense diagram explaining how their reference platform works. The Kinect is the first (and only) implementation of this platform.
  • One camera (and one IR transmitter) provide input for the depth map (rumored to be just 320x240), while the third camera detects the human visual spectrum at 640x480 resolution.
  • We have heard claims that the system can measure distance within 1cm of accuracy at two meters. While that's great in concept, early reviews are showing that you don't get anywhere near that accuracy in the real world—yet.
first image
Add Note Edit Step 12  ¶
  • All four microphones connect to the motherboard with a single cable connector.
  • After removing three connectors and seven T10 Torx screws, the top board can be separated from the other two boards.
first image
thumb image 1
thumb image 2
Add Note Edit Step 13  ¶
  • After heating up the adhesive on the heat sink with a heat gun, a spudger may be used to pry it off the motherboard with little trouble.
first image
Add Note Edit Step 14  ¶
  • The brains of the Kinect. The folks at UBM TechInsights helped us identify many of these chips. You can see a high resolution scan of this board here.
  • Wolfson Microelectronics WM8737G - Stereo ADC with microphone preamp
  • Fairchild Semiconductor FDS8984 - N-Channel PowerTrench MOSFET
  • NEC uPD720114 - USB 2.0 hub controller
  • H1026567 XBOX1001 X851716-005 GEPP (Help us identify this 6 mm x 4.9 mm SAP package. Possibly SPI flash, maybe Atmel?)
  • Marvell AP102 – SoC with Camera interface controller
  • Hynix H5PS5162FF 512 megabit DDR2 SDRAM
first image
Add Note Edit Step 15  ¶
  • Analog Devices AD8694 – Quad, Low Cost, Low Noise, CMOS Rail-to-Rail Output Operational Amplifier
  • TI ADS7830I - 8-Bit, 8-Channel Sampling A/D Converter with I2C Interface
  • Allegro Microsystems A3906 - Low Voltage Stepper and Single/Dual DC Motor Driver
  • ST Microelectronics M29W800DB - 8 Mbit (1Mb x8 or 512Kb x16) NV Flash Memory
  • PrimeSense PS1080-A2 - SoC image sensor processor
first image
thumb image 1
thumb image 2
Add Note Edit Step 16  ¶
Next » « Previous
Required Tools
Phillips #0 Screwdriver
$4.95 · 50+ in stock
Spudger
$2.95 · 50+ in stock
T6 Torx Screwdriver
5mm Nut Driver
$9.95 · 10 in stock
Metal Spudger
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 44 in stock
Anti-Static Wrist Strap
$7.95 · 50+ in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Popular Products
Solder
Kapton Tape
$9.95 · 50+ in stock
Notes Add Note Notes are offturn on
