first image
Add Note Step 9
  • Disconnecting the hard drive.
  • To replace the hard drive, you'll need a T6 Torx screwdriver to transfer the hard drive mounting screws to the new drive.
first image
Add Note Step 10
  • The bottom panel is attached by 8 screws:
    • One 3 mm Phillips in the top left corner.
    • Four 3.5 mm Phillips along the bottom.
    • Three 13.8 mm Phillips along the top.
first image
Add Note Step 11
  • Removing the bottom panel provides access to the RAM, optical drive, display hinge, fan, and logic board.
  • It looks like the only really hard part to replace will be the upper case and keyboard.
first image
Add Note Step 12
  • Removing the RAM
  • 2GB (two 1GB SO-DIMMs) of 1066MHz DDR3 SDRAM are included. Apple will upgrade the RAM to 4GB for an extra $150.
  • Apple claims this machine maxes out at 4GB RAM, but the Montevina chipset appears to support up to 8GB.
  • Shameless plug: You can upgrade your existing MacBook or MacBook Pro to 4 GB. We'll also be offering the RAM for the new Unibody machines in the near future.
first image
Add Note Step 13
  • We've now exhausted the installation instructions Apple printed on the back of the battery cover.
  • Disconnecting the subwoofer and optical drive cables.
first image
Add Note Step 14
  • The optical drive is held in by the following 4 screws:
    • Three 2.5 mm Phillips.
    • One 3.7 mm Phillips.
  • Apple gives the following specification: 8x SuperDrive (DVD±R DL/DVD±RW/CD-RW).
first image
thumb image 1
thumb image 2
Add Note Step 15
  • The optical drive, now SATA.
  • The optical drive shows a manufacture date of October 2008. That drive sure got from the factory to us fast!
first image
Add Note Step 16
  • Removing the logic board.
  • This may be the most beautiful laptop we've disassembled. Apple has a right to be proud of their engineers and manufacturing team.
Add NoteNotes: Step 12
Flag Reply by fairleymac Apr 3 @ 9:06 AM
It's been tested... 6GB max. Why? Who knows, but the computer will not recognize 8GB (and a 4GB chip for this machine is still stupid expensive...)
