iFixit
Add Note
MacBook Unibody Model A1278 Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
We disassembled this computer on October 15, 2008.
View: Paginated Full width Slideshow
first image
Add Note Edit Step 1 — MacBook Unibody Model A1278 Teardown
  • Apple boasts that, "The new MacBook packaging is 41 percent smaller than the previous generation" and is made from recycled material.
  • Smaller packaging, they say, means fewer planes to transport the same number of products.
  • Follow our updates on twitter.
first image
Add Note Edit Step 2
  • It looks like a MacBook Air from the top, but it's about 25% thicker than the thickest part of the Air, and almost 6 times thicker than the thinnest part.
  • To be fair, though, it's about 12 percent thinner than its predecessor (0.95 in vs. 1.08 in) and 10 percent lighter (4.5 pounds vs. 5 pounds).
first image
Add Note Edit Step 3
  • In the box:
    • 85-page user's manual
    • Restore DVDs
    • 60-watt AC adapter
    • AC adapter extension cable
    • Cleaning cloth
  • As with previous MacBooks, there's no video adapter included. There's an empty spot in the box where it would fit nicely, but there's no adapter to be found. Apple offers the DisplayPort adapter for $29 extra.
first image
Add Note Edit Step 4
  • There's a new Mini DisplayPort (fourth from the right), and a complete lack of a FireWire port.
  • It may be hard to tell from the image, but there are now 8 lights on the battery indicator, and it's conveniently located where you can actually see it.
first image
Add Note Edit Step 5
  • Opening the battery latch.
  • For those hurt by the financial crisis, a coin is no longer required.
first image
Add Note Edit Step 6
  • The hard drive is on the left, and the battery is on the right.
  • The new MacBook uses the same, hard drives as previous MacBook models.
  • Shameless plug: If you're not ready for a new machine, you can upgrade the hard drive in any Apple laptop. We have free guides for most models that make hard drive replacements easy.
first image
Add Note Edit Step 7
  • The battery is 45 watt-hours compared to 55 on the previous generation. It's also almost 20 percent lighter (302 g vs. 402 g).
  • Still, Apple claims that you'll get 5 hours of wireless productivity (with the display brightness set to 50 percent).
first image
Add Note Edit Step 8
  • The hard drive is held down by a single Phillips screw.
  • Like the last black MacBook, the standard hard drive on the 2.4 GHz model is 250GB SATA and 5400 rpm.
Next » « Previous
Tools
Tool image
Phillips #00 Screwdriver
$4.95 · 573 in stock
Tool image
Anti-Static Wrist Strap
$2.95 · 96 in stock
Tool image
T6 Torx Screwdriver
$4.95 · 329 in stock
Tool image
Spudger
$2.95 · 1077 in stock
Popular Repair Guides
Blurb image
Installing iPod Classic Battery
Battery not lasting long? Swap...
311 recent views
Blurb image
Installing PlayStation 3 Hard...
Replace the hard drive on your PS3.
189 recent views
Blurb image
Installing MacBook Core Duo...
The plastic frame around your...
173 recent views
Blurb image
Installing PowerBook G4 Aluminum...
This motherboard includes all...
76 recent views
Notes Add Note Notes are off | turn on
