MacBook Air 13" Mid 2012 Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
Apple announced the updated MacBook Air yesterday at WWDC, so, naturally, we're taking one apart. Join us as we dig into the new 13" MacBook Air, equipped with USB 3.0 and MagSafe 2.
You like what you see? Want to see more? Follow us on Twitter to stay up-to-date with all the latest teardowns!
Image #1 Image #2
Add Note Edit Step 1 — MacBook Air 13" Mid 2012 Teardown  ¶
  • It's so light that it almost floats off the table…
  • So, what did Apple manage to pack into its ultra-slim ultrabook this time?
    • Intel Ivy Bridge Core i5 processor with Turbo Boost
    • Intel HD Graphics 4000
    • 128 GB flash memory
    • 4 GB 1600 MHz DDR3L RAM
    • USB 3.0
    • MagSafe 2
Image #1 Image #2
Add Note Edit Step 2  ¶
  • Even with the amazingly slim profile, Apple managed to cram some nifty ports on the new Air.
    • Although we would never accuse the Air of being bulky, we were surprised that Apple didn't make this iteration thinner than the previous model.
  • Accompanying the audio jack on the left side of the MacBook are the new MagSafe 2 connector and the first of two USB 3.0 ports.
  • On the opposite side, we find an SD card reader, the second USB 3.0 port, and—of course—Apple and Intel's brainchild: the Thunderbolt I/O.
Image #1
Add Note Edit Step 3  ¶
  • This is very unlike Apple; even though the MacBook Air is only slightly refreshed, they gave it a new model number: A1466.
  • We get pretty excited about new model numbers because they make it much easier for us to help people ID their Macs for service.
  • Only time will tell if the new MacBook Pro with Retina display will finally break the A1278 chain, but that discussion is for another time.
Image #1 Image #2
Add Note Edit Step 4  ¶
  • MagSafe 2 is a luxury reserved (so far) for the new MacBook Air and the Retina display-equipped MacBook Pro.
  • As you can see, the new MagSafe 2 connector (bottom) is much thinner and wider than its predecessor. This is pretty significant, because the thickness of Apple's devices seems to be limited only by the size of their ports.
    • Imagine how thin of a device they could make if all communication and charging were done wirelessly…
  • Apple sells a $10 MagSafe 2 adapter, so you don't have to throw away your 27" Thunderbolt Display. Phew.
  • Apple never stops tweaking the details; they moved the symbols from the rear side of the ports to the front. If you're in a pinch and have to differentiate a Mid 2012 MacBook Air from a Mid 2011 model, just look at what side of the ports the symbols are on.
Image #1 Image #2 Image #3
Add Note Edit Step 5  ¶
  • There was tension in the Air as we encountered a few unknown sized, Apple-proprietary, pentalobe screws on the back of the new Air.
  • Fortunately, we have tools for that. Our pentalobe screwdriver made quick work of those pesky proprietary screws.
  • By the way, we don't just make awesome teardowns—we sell parts. And tools! Lots and lots of tools.
  • Like this handy-dandy electronics tool kit that we used to take apart the new iPad. You know you want one. It'll pay for itself the first time you use it!
  • We sell Mac parts & upgrades, parts for iPhone screen repair, kits for fixing the infamous Xbox Red Ring of Death, and tons more.
  • We need your support to continue building the free repair manual for everything in the world.
Add Note Edit Step 6  ¶
  • After removing the screws, the back comes off to reveal the internals.
  • Keeping all the screws we removed organized is easy with our Magnetic Project Mat.
  • As with most mobile devices, the majority of the space is filled by the battery.
  • The inside of this newly configured Air is very similar to last year, with a few minor layout changes.
Add Note Edit Step 7  ¶
  • A connector and some T5 screws are all that stand between us and ultimate power—or at least the power source for the Air.
  • This battery is the exact same model as the one found in the Mid 2011 MacBook Air, so it comes as no surprise that the 13" model has the same 7 hour battery life as its predecessor.
  • We'll go ahead and answer the question before it's asked: yes, you can swap 2011 and 2012 batteries. We're not really sure why you would, though, considering they are exactly the same.
Add Note Edit Step 8  ¶
  • At first glance, the 128 GB SSD is almost exactly the same as last year's.
  • But upon closer inspection, the connector for this model's flash memory module is slightly different than last year!
  • The SSD looks to be a completely new design. The new unit appears to be based on a SandForce controller chip, but stamped with Toshiba markings.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
T5 Torx Screwdriver
$6.95 · 50+ In stock
T9 Torx Screwdriver
$4.95 · 35 In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 6 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
Popular Device Products
