MacBook 13" Unibody 2 GHz Parts
The 2 GHz model A1278 MacBook Unibody 13" does not have a backlit keyboard display.
This machine can be upgraded to 6GB of RAM using a PC3-8500 2 GB RAM chip and a PC3-8500 4 GB RAM chip. The hard drive can also be upgraded to a hefty, yet agile 500 GB 7200 RPM SATA hard drive.
Not sure what's wrong with your laptop? Check out our Troubleshooting Guide!
Select your category below or browse all compatible parts to find what you need to fix your laptop!
Results
750 GB 7200 RPM Seagate SATA Hard Drive Upgrade Kit (New)
SATA interface for Intel Macs / Seagate / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM.
See full description
$149.95
MacBook Unibody (Model No. A1278) 2.4 GHz Logic Board
2.4 GHz Motherboard / Ports: Mini DisplayPort, 1000BaseT Ethernet, 2 USB 2.0, Audio In, Audio Out
$699.95
MacBook Unibody (Model No. A1278) 2 GHz Logic Board
2 GHz Motherboard / Ports: Mini DisplayPort, 1000BaseT Ethernet, 2 USB 2.0, Audio In, Audio Out
$599.95
MacBook Unibody (Model No. A1278) Display Assembly
Includes LED assembly, iSight camera, Bluetooth card, and AirPort card.
$499.95
MacBook Unibody (Model No. A1278) Upper Case (Backlit)
Case assembly includes backlit keyboard and trackpad assembly.
$249.95–$299.95
120 GB Solid State Drive Upgrade Kit
Unformatted 2.5" 120 GB SATA SSD with everything you need to install the drive and transfer your files.
$209.95
750 GB 7200 RPM SATA Hard Drive
SATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM
$209.95
750 GB Hybrid Seagate SATA Hard Drive (New)
SSD speeds from the Momentus XT Hybrid Drive.
$199.95
SATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 120 GB Unformatted / SSD
$199.95
13" Unibody LCD Panel
Glossy or anti-glare display panels for MacBook Unibody and MacBook Pro Unibody 13.3" displays.
$109.95–$149.95
