Toshiba L15W-B1303 Battery Replacement
  1. Toshiba L15W-B1303 Battery Replacement, Bottom Panel: step 1, image 1 of 3 Toshiba L15W-B1303 Battery Replacement, Bottom Panel: step 1, image 2 of 3 Toshiba L15W-B1303 Battery Replacement, Bottom Panel: step 1, image 3 of 3
    • Turn the laptop over and place it on its top side.
    • Remove ten 10mm JIS #00 screws from the bottom panel of the laptop.
    • Using the iFixit opening tool, remove the bottom panel of the laptop.
  2. Toshiba L15W-B1303 Battery Replacement, Battery: step 2, image 1 of 3 Toshiba L15W-B1303 Battery Replacement, Battery: step 2, image 2 of 3 Toshiba L15W-B1303 Battery Replacement, Battery: step 2, image 3 of 3
    • Lift the battery and remove it from the laptop.
    • The battery's cable connector is still attached to the laptop, so lift the battery out carefully.
    • Disconnect the battery carefully from the port by detaching the connector with a plastic opening tool or a spudger.
Peyton Campbell
145 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 16
All Time: 410
