Introduction
Use this guide to replace a worn out or dead battery in a SteelSeries Nimbus+ controller.
For your safety, discharge the battery below 25% before disassembling your controller. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
You’ll need replacement adhesive when reassembling your device.
Use your fingers to remove the phone mount by pulling it straight out of the controller.
Use your fingers to remove the sticker located on the back cover of the Nimbus+.
Use a Y1 Tri-point screwdriver to remove the five 9.1 mm-long screws securing the back cover.
Insert an opening pick into the gap between the front and back cover assembly at the outside of the right controller handle.
Slide the opening pick to the top of the controller to release the remaining plastic clips on the right edge.
Insert an opening pick into the gap between the front and back cover assembly at the outside of the left controller handle.
Slide the opening pick to the top of the controller to release the remaining plastic clips on the left edge.
Carefully fold the back cover assembly to the top of the SteelSeries Nimbus+ and bring it in an 90 degree angle.
Insert the edge of an opening pick into the gap between the battery and the back cover assembly.
Use the opening pick to carefully pry up the battery and loosen the adhesive.
For optimal performance, calibrate your newly installed battery after completing this guide.
