Sony Cyber-Shot DSC-W830 LCD Replacement
  1. Sony Cyber-Shot DSC-W830 LCD Replacement, Battery: step 1, image 1 of 1
    • Slide the lock at the bottom of the camera to "Open".
    • The door to the battery pack is spring loaded.
  2. Sony Cyber-Shot DSC-W830 LCD Replacement: step 2, image 1 of 1
    • Slide the blue clip up and away from the battery.
  3. Sony Cyber-Shot DSC-W830 LCD Replacement: step 3, image 1 of 1
    • Remove the battery.
  4. Sony Cyber-Shot DSC-W830 LCD Replacement, Front and Back Panel: step 4, image 1 of 3 Sony Cyber-Shot DSC-W830 LCD Replacement, Front and Back Panel: step 4, image 2 of 3 Sony Cyber-Shot DSC-W830 LCD Replacement, Front and Back Panel: step 4, image 3 of 3
    • Remove the six 3.5mm Phillips #000 screws.
    • Rotate the lock away from the camera.
  5. Sony Cyber-Shot DSC-W830 LCD Replacement: step 5, image 1 of 3 Sony Cyber-Shot DSC-W830 LCD Replacement: step 5, image 2 of 3 Sony Cyber-Shot DSC-W830 LCD Replacement: step 5, image 3 of 3
    • Pry the device open with the plastic opening tool.
    • There are two clips that help prevent the front panel from separating.
  6. Sony Cyber-Shot DSC-W830 LCD Replacement: step 6, image 1 of 3 Sony Cyber-Shot DSC-W830 LCD Replacement: step 6, image 2 of 3 Sony Cyber-Shot DSC-W830 LCD Replacement: step 6, image 3 of 3
    • Remove the two plastic spacers between the front and the back panels.
    • The spacers may fall out when removing the panels.
    • Carefully remove the back panel.
  7. Sony Cyber-Shot DSC-W830 LCD Replacement, Button Board: step 7, image 1 of 2 Sony Cyber-Shot DSC-W830 LCD Replacement, Button Board: step 7, image 2 of 2
    • Gently release the button board from the clips.
    • Be careful when lifting the button board; the ribbon cable will still be attached.
  8. Sony Cyber-Shot DSC-W830 LCD Replacement: step 8, image 1 of 2 Sony Cyber-Shot DSC-W830 LCD Replacement: step 8, image 2 of 2
    • Disconnect the no-fuss ribbon cable by gently pulling it out of the button board.
  9. Sony Cyber-Shot DSC-W830 LCD Replacement, LCD: step 9, image 1 of 2 Sony Cyber-Shot DSC-W830 LCD Replacement, LCD: step 9, image 2 of 2
    • Push the bottom right corner of the LCD screen out and slide it to the right to release it from the clips.
    • Be careful when lifting the LCD screen; the ribbon cable will still be attached.
  10. Sony Cyber-Shot DSC-W830 LCD Replacement: step 10, image 1 of 2 Sony Cyber-Shot DSC-W830 LCD Replacement: step 10, image 2 of 2
    • Grasp the no-fuss ribbon cable and gently pull it out from the motherboard.
4 other people completed this guide.
Addyson Salalila
301 Reputation
2 Guides authored
USF Tampa, Team 17-1, Blackwell Fall 2016 Member of USF Tampa, Team 17-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G1
4 Members
6 Guides authored
5 Comments
hii
plaz help me
tajbhatnagar - Reply
Sony Cyber-Shot DSC-W830 LCD ……WowObjects LCD Display Screen For SONY DSC-W150 same hai ya different hai
Hi I need a one DSC w810 display how much. ?
How can contact you ?
Tamil Varshitha - Reply
Sony dsc s2000 model camera need
Display & lens unit
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 54
All Time: 4,249
