Shark AI Ultra AV2511AE Vacuum Battery Replacement
  1. Shark AI Ultra AV2511AE Vacuum Battery Replacement, Vacuum Battery: step 1, image 1 of 2 Shark AI Ultra AV2511AE Vacuum Battery Replacement, Vacuum Battery: step 1, image 2 of 2
    • Orient the device upside-down
    • Remove two 15 mm screws using a Phillips #1 screwdriver.
    • Remove the battery cover.
  2. Shark AI Ultra AV2511AE Vacuum Battery Replacement: step 2, image 1 of 3 Shark AI Ultra AV2511AE Vacuum Battery Replacement: step 2, image 2 of 3 Shark AI Ultra AV2511AE Vacuum Battery Replacement: step 2, image 3 of 3
    • Using the two paper tabs on each side of the battery, slide it up and out of the robot.
    • Using an opening tool, disconnect the wire connector from the robot.
    • Remove the battery.
Gisela Benavides
241 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 16
All Time: 161
