Sega CD Motherboard/AC Power Board Replacement
  1. Sega CD Motherboard/AC Power Board Replacement, Sega CD Plastic Housing Removal: step 1, image 1 of 2 Sega CD Motherboard/AC Power Board Replacement, Sega CD Plastic Housing Removal: step 1, image 2 of 2
    • Using a Phillips head screwdriver remove six screws from the bottom of the console.
    • The six screws are marked.
  2. Sega CD Motherboard/AC Power Board Replacement: step 2, image 1 of 1
    • Remove the two screws that attach the Genesis' connector to the rest of the console.
    • The two screws are marked in the diagram.
  3. Sega CD Motherboard/AC Power Board Replacement: step 3, image 1 of 1
    • Slide the lock tab to the left to separate the halves of the console.
  4. Sega CD Motherboard/AC Power Board Replacement: step 4, image 1 of 1
    • Lift from the left side to remove the top of the case.
  5. Sega CD Motherboard/AC Power Board Replacement: step 5, image 1 of 1
    • Using the spudger, pry the cover off of the Genesis attachment.
  6. Sega CD Motherboard/AC Power Board Replacement: step 6, image 1 of 1
    • Lift the top of the case to remove the cover.
  7. Sega CD Motherboard/AC Power Board Replacement: step 7, image 1 of 1
    • Remove the faceplate by pulling it up, then out.
  8. Sega CD Motherboard/AC Power Board Replacement, CD Tray: step 8, image 1 of 2 Sega CD Motherboard/AC Power Board Replacement, CD Tray: step 8, image 2 of 2
    • Remove metal plate by unscrewing the three screws with the Phillips head screwdriver and then lifting the plate.
    • The three screws are shown on the diagram.
  9. Sega CD Motherboard/AC Power Board Replacement: step 9, image 1 of 2 Sega CD Motherboard/AC Power Board Replacement: step 9, image 2 of 2
    • Remove the two screws from the plastic bar.
    • The two screws are shown pictured.
  10. Sega CD Motherboard/AC Power Board Replacement: step 10, image 1 of 2 Sega CD Motherboard/AC Power Board Replacement: step 10, image 2 of 2
    • To remove the CD tray
    • Remove the four screws with the Phillips head screwdriver.
  11. Sega CD Motherboard/AC Power Board Replacement: step 11, image 1 of 1
    • Carefully unplug the wire connected to optical reader.
  12. Sega CD Motherboard/AC Power Board Replacement: step 12, image 1 of 2 Sega CD Motherboard/AC Power Board Replacement: step 12, image 2 of 2
    • Remove the four screws on the underside of the CD tray with a small Phillips head screwdriver.
    • The four screws are highlighted on the diagram.
    • The four springs below the circuit board are attached to the screws, so be careful not to lose them when you remove the screws.
  13. Sega CD Motherboard/AC Power Board Replacement: step 13, image 1 of 1
    • Carefully remove the CD tray from circuit board.
  14. Sega CD Motherboard/AC Power Board Replacement, Motherboard/AC Power Board: step 14, image 1 of 3 Sega CD Motherboard/AC Power Board Replacement, Motherboard/AC Power Board: step 14, image 2 of 3 Sega CD Motherboard/AC Power Board Replacement, Motherboard/AC Power Board: step 14, image 3 of 3
    • Remove the two bronze screws from the metal plate with a medium Phillips head screwdriver.
    • The screws are marked on the diagram.
    • Carefully lift the metal plate up to expose the motherboard.
    • There is a wire strip running through the metal plate that is soldered to motherboard and power supply board. The plate cannot be completely removed. Do NOT force plate upwards. All the ribbon cables can be safely unplugged by simply pulling them out of their slots.
  15. Sega CD Motherboard/AC Power Board Replacement: step 15, image 1 of 2 Sega CD Motherboard/AC Power Board Replacement: step 15, image 2 of 2
    • Carefully lift off the metal plate, the motherboard, and the CD tray circuit board. Then, flip each piece over, as pictured.
  16. Sega CD Motherboard/AC Power Board Replacement: step 16, image 1 of 3 Sega CD Motherboard/AC Power Board Replacement: step 16, image 2 of 3 Sega CD Motherboard/AC Power Board Replacement: step 16, image 3 of 3
    • Remove the two screws from the power supply using a medium Phillips head screwdriver.
    • The two screws are marked on the diagram.
  17. Sega CD Motherboard/AC Power Board Replacement: step 17, image 1 of 1
    • Remove the power supply unit from the console by lifting the unit up.
  18. Sega CD Motherboard/AC Power Board Replacement: step 18, image 1 of 1
    • This is what the motherboard unit will look like once removed.
5 other people completed this guide.
Ryan Kotzebue
271 Reputation
4 Guides authored
Cal Poly, Team 5-14, Maness Fall 2010 Member of Cal Poly, Team 5-14, Maness Fall 2010
CPSU-MANESS-F10S5G14
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 58
All Time: 10,554
