Samsung NP900X4B Battery Replacement
  1. Samsung NP900X4B Battery Replacement, Battery: step 1, image 1 of 2 Samsung NP900X4B Battery Replacement, Battery: step 1, image 2 of 2
    • Ensure computer is unplugged and powered down before continuing.
    • Remove the ten screws along the base using a Phillips #000.
    • Use a Plastic Opening Tool to pry open the base .
  2. Samsung NP900X4B Battery Replacement: step 2, image 1 of 1
    • The battery is now unobstructed from your view.
    • Before removing the battery, use the plastic opening tool to detach the ribbon wire cable that connects the battery to the motherboard.
  3. Samsung NP900X4B Battery Replacement: step 3, image 1 of 2 Samsung NP900X4B Battery Replacement: step 3, image 2 of 2
    • Use the Phillips #000 screwdriver to remove six screws that are holding the battery in place.
  4. Samsung NP900X4B Battery Replacement: step 4, image 1 of 1
    • Lift and pull out the battery.
Nathan LeBlanc
109 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 15
All Time: 612
