Replacing Apple Time Capsule HDD
User-Contributed Guide
This guide is not managed by iFixit staff.
Grammatical Errors
Grammatical Errors
This guide has grammatical errors or does not meet iFixit's writing guidelines.
  • Author: rousp
  • Time required: 30 - 60 minutes
  • Difficulty: Moderate
  • Add Note x
  • x 35
Replacing the HD in Apple's Time Capsule.
first image
thumb image 1
thumb image 2
Add Note Edit Step 1 — Lower Case  ¶
  • Place the unit upside down on your work surface. Use a cloth or similar object to protect it from scratches.
  • Use a heat gun or hair dryer to heat the underside of the unit, in order to weaken the adhesives in the tape that hold it in place.
    • Start in a corner, it can be tricky to get a good grip at first.
    • Progress slowly not to tear the tape, but do not over heat the unit.
    • If you tear some of the tape, don't worry too much about it. It will still hold in place fairly well.
first image
Add Note Edit Step 2  ¶
  • Remove the 8 Phillips PH-0 screws highlighted on the photograph.
  • Some revisions of the Time Capsule may have 10 screws. If your Time Capsule has two screws each in the upper left and bottom right, make sure to remove all 10 screws.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3  ¶
  • With the rear side of the device (with Ethernet connectors) facing you, carefully pull up on the left side of the metal plate.
  • The fan is attached to the metal plate, and connected to the logic board next to the power connector. To prevent damage, do not lift the plate straight up or use force.
  • Disconnect the fan from the logic board using a spudger or tweezers to pry the cable out of the connector.
Next » « Previous
