Technique: Optical Drive Disc Removal Technique, or Foreign Object Removal
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
  • Add Note x
  • x 121
Did your optical drive devour your favorite CD? Did your 3-year-old fill the slot with coins? Worry no more! This guide will show you how to remove a jammed disk or foreign object from your optical drive.
Image #1
Add Note Edit Step 1 — Optical Drive Disc Removal Technique, or Foreign Object Removal  ¶
  • With the optical drive removed from the computer, remove the screws securing the top panel of the optical drive.
Image #1 Image #2 Image #3
Add Note Edit Step 2  ¶
  • With the screws removed, shift the top panel slightly toward the rear of the optical drive so the retaining tabs clear the body of the drive.
  • Lift the top panel off the optical drive.
Image #1
Add Note Edit Step 3  ¶
  • Remove any objects stuck in the optical drive.
  • If a disk is stuck in the drive, simply lift it off the spindle motor.
Required Tools
Phillips #00 Screwdriver
$4.95 · 8 In stock
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
Inspection Scope
$39.95 · 18 In stock
Frictionless Ratchet
$24.95 · 2 In stock
Portable Anti-Static Mat
$24.95 · 17 In stock
Popular Products
Unibody Laptop Dual Drive
$39.95 · 3 In stock
iPad 2 Adhesive Strips
$6.95 · 47 In stock
iPhone 4S Dock Connector
$34.95 · 20 In stock
