Installing iPod Nano 6th Generation Outer Case
Replace the aluminum outer casing on your 6th generation iPod Nano.
Use this guide to replace your iPod Nano's outer casing.
Embed this guide With the HTML code below, you can embed this guide as a small widget on your website.
Edit Step 1
Front Panel Assembly
Use a heat gun or hair dryer to soften the adhesive securing the perimeter of the front panel assembly to the outer case.
Be careful not to overheat the front panel assembly, as it may result in damage to the LCD.
While the front panel is still warm, use the edge of an iPod opening tool to pry it from the headphone jack side of the front panel assembly out of the Nano.
Do not attempt to pry out the front panel assembly from the left side of the device, as the display data cable may be damaged in the process.
Continue prying the perimeter of the front panel assembly out of the outer casing, being careful not to damage the display data cable held under its left edge.
If the front panel is excessively difficult to lift out of the outer case, reheat the area and try again.
Lift the front panel assembly from the headphone jack side of the Nano.
Pull the front panel assembly slightly away from the left side of the Nano to clear the display data cable.
The front panel assembly is still attached to the Nano by two cables.
Edit Step 8
Logic Board Assembly
Use an iPod opening tool to gently pry the battery up from the adhesive securing it to the outer case.
Use your thumb to pull the battery toward the left side of the Nano as you pry the battery's other edge out of the outer case.
Use your iPod opening tool to gently push the dock connector toward the center of the Nano.
Remove the logic board assembly from the Nano, being careful not to damage the headphone jack assembly cable.
Edit Step 13
Headphone Jack Assembly
Use a pair of tweezers to carefully pull the headphone jack toward the center of the Nano.
Avoid pulling on the cable, as it is very thin and delicate. The plastic mounting ear is a safer area to pull on.
Edit Step 16
Outer Case
Remove the clip from the outer case.
Outer case remains.
When reinstalling the clip, it is necessary to squeeze the base of the clip very tightly against the outer case as you insert the first screw.
For more information, check out the iPod Nano 6th Generation
device page .
Fantastic! Great work!
Your profile has been updated to show that you completed Installing iPod Nano 6th Generation Outer Case. Change your mind? Oops, I actually didn't do it.
Did you successfully follow this guide? I did it! Success!
This guide has been completed 0 times.
