Page 1 of 1
Installing iPad Wi-Fi Battery Replacement
Replace your iPad Wi-Fi's internal lithium battery.
- Author: Walter Galan
- Difficulty: Moderate
Use this guide to replace your iPad's battery.
- View:
- Paginated
- Full width
Edit
Step 1
Display Assembly
Insert a metal spudger between the top edge of the display assembly and the rear panel assembly.
Rotate the spudger away from you to release the tabs along the top edge of the display.
Insert a second metal spudger between the top edge of the display assembly and the rear panel assembly to keep the tabs from snapping back into place.
Edit
Step 2
With one spudger, work your way along the right edge of the iPad.
The front panel is held to the aluminum back by metal clips on the top, bottom, and left sides. The right side has plastic tabs which slide into recesses in the backplate.
Once the clips are released, lift the left side of the front panel up and slide it to the left to clear the tabs from the aluminum backplate.
Edit
Step 9
Logic Board
Use the edge of a plastic opening tool to:
Pry the side button connector up off the logic board from underneath the wires.
Pry the speaker connector up off its socket on the logic board from beneath the speaker wires.
Carefully flip up the ZIF ribbon cable retaining flap on the socket near the headphone jack.
Be sure you are prying up on the retaining flap, not the socket itself.
Pull the headphone jack ribbon cable toward the left side of the iPad to disconnect it from its socket.
Edit
Step 19
The battery is held to the rear panel by an excessive amount of adhesive. Proceed with patience and caution.
Use the flat end of a spudger to gently pry the battery up from the the lower case.
Gently continue to enlarge the gap by wiggling the spudger and running it along the right side of the battery.
Continue to pry until the right side of the battery is free from the rear panel.
This guide has been completed 6 times.
Page 1 of 1
