Installing Xbox 360 Wireless Controller Analog Stick Covers
Analog stick grip replacement.
  • Add Note x
  • x 7
Steady your aim by replacing the analog stick grips on the Xbox 360 wireless controller.
Sections
first image
thumb image 1
thumb image 2
  • Depress the battery release button on the top of the controller.
  • Remove the battery holder from the controller.
  • The standard option for Xbox 360 Wireless Controllers Battery Packs is AA batteries inside the battery holder. A rechargeable battery is available also, but both options are removed from the controller in the same way.
first image
Add Note Edit Step 2 — Rear Case  ¶
  • Use a pair of tweezers to peel the barcode sticker from the battery compartment.
first image
Add Note Edit Step 3  ¶
  • Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ in stock
T8 Torx Security Bit Screwdriver
$6.95 · 50+ in stock
Popular Products
iPhone 4S Display Assembly
$174.95 · 11 in stock
iPhone 4S Rear Glass Panel
$79.95 · 19 in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Precision Screw Extractor Set
$19.95 · 50+ in stock
Notes Add Note Notes are offturn on
