Motorola RAZR V3i Battery Replacement
  1. Motorola RAZR V3i Battery Replacement, Battery: step 1, image 1 of 1
    • Make sure the phone is turned off by holding down the red End Call/Power button until the phone shuts off.
    • If you have a phone case, it has to be removed.
  2. Motorola RAZR V3i Battery Replacement: step 2, image 1 of 3 Motorola RAZR V3i Battery Replacement: step 2, image 2 of 3 Motorola RAZR V3i Battery Replacement: step 2, image 3 of 3
    • Close the phone and find the battery cover button, located on the backside of the phone underneath the hinge.
    • Using your finger, press down on the button to release the back cover. Then, lift the cover and remove it from the phone completely.
    • The flat edge of a credit card or other flat object will also work.
  3. Motorola RAZR V3i Battery Replacement: step 3, image 1 of 3 Motorola RAZR V3i Battery Replacement: step 3, image 2 of 3 Motorola RAZR V3i Battery Replacement: step 3, image 3 of 3
    • Remove the battery by pushing down on it from the top while gently pulling it outwards.
    • Be careful not to use too much force as the battery retaining tab could be damaged.
Finish Line
5 other people completed this guide.
Nigel
133 Reputation
2 Guides authored
Cuesta, Team 1-5, Zipperian Fall 2011 Member of Cuesta, Team 1-5, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G5
1 Member
2 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 53
All Time: 7,193
